Are all retainers created equal?
Old Mar 27, 2007 | 01:31 PM
Mashimaro's Avatar
Default Are all retainers created equal?
Question for the all motor guys:
Are all retainers pretty much the same? I hear stories of Titanium ones wearing or breaking, others saying to stick with OEM ITR ones, etc...
i'll be installing a set of Toda B's into a JDM R-motor soon along with Toda valvesprings.
retainer-wise, i'm thinking of going with just skunk2 ones. Anyone opinions on these pieces of flat metal that cost a lot?
thanks!
Old Mar 27, 2007 | 01:46 PM
Sam92Teg's Avatar
Default Re: Are all retainers created equal? (Mashimaro)
There is a large thread on titanium retainers, you can search for that or chromoly to find the thread.
Old Mar 27, 2007 | 02:02 PM
slofu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mashimaro &raquo;</TD></TR><TR><TD CLASS="quote">Anyone opinions on these pieces of flat metal that cost a lot?</TD></TR></TABLE>
just drill a hole thru a stack of nickels and you're set for $0.80.
Old Mar 27, 2007 | 02:28 PM
spun Vtec's Avatar
Default Re: Are all retainers created equal? (slofu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slofu &raquo;</TD></TR><TR><TD CLASS="quote">
just drill a hole thru a stack of nickels and you're set for $0.80. </TD></TR></TABLE>
haha
Old Mar 28, 2007 | 08:33 AM
Mashimaro's Avatar
LOL! perhaps if i use some Japanese Yen, i'll have some hardcore JDM retainers too
(the search seems to come up with vague opinions of retainers..)
anyone?
Old Mar 28, 2007 | 11:07 AM
bluedlude's Avatar
check out this link and read the Physical properties. that should say it all.
http://en.wikipedia.org/wiki/Titanium
Old Mar 28, 2007 | 11:35 AM
Mashimaro's Avatar
Default Re: Are all retainers created equal? (bluedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude &raquo;</TD></TR><TR><TD CLASS="quote">check out this link and read the Physical properties. that should say it all.
http://en.wikipedia.org/wiki/Titanium </TD></TR></TABLE>
thanks for the link dood.
i was a bit confused cuz i didn't know that titanium would wear out faster than steel. however, i don't think i was asking about titanium retainers...but it's not that i'm not grateful so thanks for the link.
Old Mar 28, 2007 | 12:04 PM
bluedlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mashimaro &raquo;</TD></TR><TR><TD CLASS="quote">Question for the all motor guys:
thanks! </TD></TR></TABLE>
Old Mar 28, 2007 | 01:19 PM
Mashimaro's Avatar
Thanks for your input dood!
Old Mar 28, 2007 | 04:07 PM
dinko's Avatar
are you asking if the titanium retainers are the same from company to company?
Old Mar 29, 2007 | 07:34 AM
Mashimaro's Avatar
Default Re: Are all retainers created equal? (dinko)
well, i was asking if there was any problems with the Skunk2 ones, or perhaps recommendations from personal experience?
Old Mar 29, 2007 | 08:43 AM
bluedlude's Avatar
just get some chromoly retainers and call it a day.
Old Mar 29, 2007 | 09:13 AM
Mashimaro's Avatar
any particular brands i should stay away from?
Old Mar 29, 2007 | 11:39 AM
Skunk2Tony's Avatar
Just thought I'd share some info here. 1) All Ti retainers are not created equal. 2) They will wear out faster then steel ones and many people have different opinions on Ti's life expectancy. A handful of companies make Ti retainers and Im sure they are all good and have a performance benefit, but they are not all machined equal.
Heres some info on the Skunk2 ones:
From the 2007 catalog:
Many enthusiasts may wonder why Skunk2 spends so much time and effort into designing valvetrain components with reduced weight. Why is it so important for us to chase after grams? Without getting into the mathematics we thought we would try to provide enthusiasts with a simple explanation. By replacing Stock valvetrain components with Skunk2 Valves, Valvespings, and Retainers reciprocating mass can be reduced by an average of 12-14 grams. 1 gram is equivalent to the weight of a paper clip, which may not seem like much weight, but at 9000 rpm, 14g result in a force of approximately 32kg or 70lbs. Reducing the force that the spring needs to control greatly improves valvetrain stability, high rpm performance, and power output. Skunk2 Pro-Series titanium retainers are CNC-machined in-house from certified medical grade titanium that is milled in the USA
Old Mar 29, 2007 | 11:51 AM
dinko's Avatar
Default Re: Are all retainers created equal? (Skunk2Tony)
^^ this is what I was wondering...do they all look the same or does each company have their own distinct "style"
here's the RM from m24x.com. from the picture you provided us...right off the bat the top of these look different than the skunk2's
Old Mar 29, 2007 | 01:05 PM
GarageAlchemist
Guest
Posts: n/a
some really good info here.
" 1 gram is equivalent to the weight of a paper clip, which may not seem like much weight, but at 9000 rpm, 14g result in a force of approximately 32kg or 70lbs. Reducing the force that the spring needs to control greatly improves valvetrain stability, high rpm performance, and power output. "
thats pretty awesome when you look at it... i wonder what would happen if you took a stock d16z6, no aftermarket parts what so ever, and just shaved grams here and there, balanced, and rebuild how much power it would make.. what kinda changes in the power band, etc..
intresting...
Old Mar 29, 2007 | 01:28 PM
Mashimaro's Avatar
dinko - are those retainers made of Ti as well?
i thought Skunk2 had cromoly/steel retainers too?
guys, great info so far. keep the posts coming!!
Old Mar 29, 2007 | 03:15 PM
bluedlude's Avatar
my RM Ti retainers look more like the skunks than the ones that you have pictured there. they have a small radius in the top. heres the pic.
nice snap fit rocket motorsports
Modified by bluedlude at 4:33 PM 3/29/2007
Old Mar 29, 2007 | 08:16 PM
dinko's Avatar
yeah i think the pics on the website are the original ones, the one you have pictured are the ones the dealers sell now...
Reza^
Feb 26, 2007 08:00 PM
gakkuken
18
Dec 14, 2004 10:46 PM
sicdx
Dec 12, 2003 05:44 PM
alfaaay
Aug 31, 2003 08:21 AM
Kengs
Aug 10, 2001 11:02 AM
