obd1 gsr cluster in a 1990 honda civic dx
i was wondering if anybody had a write-up on how to do this...and yes i searched...got the cluster for free so wat the hell
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beatthisspeed69 »</TD></TR><TR><TD CLASS="quote">i was wondering if anybody had a write-up on how to do this...and yes i searched...got the cluster for free so wat the hell</TD></TR></TABLE>
ne body?
ne body?
they do indeed fit. you just have to remove the tabs that hold old cluster. it hangs there, and when you tighten the screws to the cluster cover it holds it still. ive had mine on for awhile now. no problems whatsoever.
in the FAQ theres a how to. check it out. ill see if i find it for you.
the only thing is that you need an electronic vss
so can i just use the plugs from any obd1 car or wat c'mon guys about to go to the junk yard and need to know c'mon plz
Modified by beatthisspeed69 at 1:14 PM 3/28/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beatthisspeed69 »</TD></TR><TR><TD CLASS="quote">so can i just use the plugs from any obd1 car or wat c'mon guys about to go to the junk yard and need to know c'mon plz
Modified by beatthisspeed69 at 1:14 PM 3/28/2007</TD></TR></TABLE>
c'mon guys
c'mon guys
you need the correct OBD-1 Integra cluster plugs 94-97 would work best. heres a shot of my ITR cluster in my CRX
You have to get the plugs made for that cluster. I have a 95 gsr cluster in my crx.
Didn't have to modify the cluster hood at all or even put screws in to hold it in place. It fits nicely.
well becuz i looked at this http://www.ef-honda.com/main/viewtopic.php?t=1400 and i got the blue plugs that are on that thread but they came on my gsr cluster so i was just thinking that i can wire it on like that thread says and it will work?????? n e body know?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodcivic510 »</TD></TR><TR><TD CLASS="quote">they fit like complete crap</TD></TR></TABLE>
have you ever done this? Ever seen it in person? It fits fine. It fits better with the newer, curved cluster hood from the 91's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beatthisspeed69 »</TD></TR><TR><TD CLASS="quote">ok i got the plugs that came off the gsr cluster but they are the 99 si plugs...they go in and everything but do i wire them up just as i would the gsr plugs</TD></TR></TABLE>
The si and gsr wires are different which only means you'll be looking at three wire diagrams instead of two when you rewire yours. You need to 'convert' your plugs to gsr and then wire your factory harness to it. Make sure to go only a couple wires at a time and SOLDER every connection.
use these charts
GSR > https://honda-tech.com/zerothread?id=1053318
Civic > http://faq.ef-honda.com/index....ng=en
hey wut kind of tranny u got???
cuz if u have a SOHC tranny u need to use the DOHC VSS,,,,, but if u have a DOHC tranny u need the SOHC VSS u can get the 96 4dr civic it fits perfect
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodcivic510 »</TD></TR><TR><TD CLASS="quote">they fit like complete crap</TD></TR></TABLE>good arguement
heres mine
heres mine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrpedro »</TD></TR><TR><TD CLASS="quote">hey wut kind of tranny u got???
Not true. They are all the same. Only difference might be the wiring for it.
</TD></TR></TABLE>Not true. They are all the same. Only difference might be the wiring for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beatthisspeed69 »</TD></TR><TR><TD CLASS="quote">ok i got everything to work except the gauge lights so which pin is the gauge lights on the gsr plugs and whick plug is it on</TD></TR></TABLE>
any body know?
any body know?
