FS: RLZ GSR Head and Cams, K20A2 Trans, IB Rods, and Many K, B, D Civic and Integra Parts
<FONT COLOR="red"><FONT SIZE="4">THIS POST WILL BE UPDATED REGULARY SO KEEP CHECKING
BACK!!!</FONT></FONT>
I will ship after payment is received. I will ship USPS Priority Mail for smaller items and FedEx ground for larger items. I will also include a tracking number or delivery confirmation number. I accept money orders, Paypal, and also pickup in the NJ area.
I have many references and vouches here on H-T, just ask around or I can send you a list.
Contact Info
AIM - Dynoair690
E-Mail - Dynoair690@aol.com
Paypal - Dynoair690@aol.com
Please click on the thumbnails for larger images
<u>RLZ GSR Clyinder Head</u>
-From my 2001 GSR
-4000 miles since rebuild
-RLZ Portwork, complete port and chamber work
-Valves de shrouded to 84.5mm, chamber volume is 42ccc
-RM Gen1 Outer valvesprings installed (will include inner springs)
-RM Ti Retainers
-RLZ Modified LMA’s
-Manley STD Valves
-New vavle guides and seals installed 4000 miles ago
-Everything else in the head is in great condtion
-Doesn't includes the Vtec Solenoid
-Made 230whp with a 2.0lt 11.5:1 C/R block
$1350 Shipped
<u>RLZ Stage 3 B-Series Cams</u>
-Used for only 3000 miles, great condition
-Great for serious all-motor setups
$400 Shipped
<u>B-Series Hydro Shift Assembly</u>
-All parts in good condition
-Inlcudes everything in the pictures
-3 shift forks, shift rod, holder assembly, interlock, etc.
-I have 2 sets for sale
$150 Shipped Each
<u>Acura RSX Type-S Final Drive (K20A2) </u>
- From a 2004 with roughly 35,000 miles
- Great condition
- Was swapped out for a 4.7 FD
$150 Shipped
<u>K24A4 Fuel Rail</u>
- Great working condition
$20 Shipped
<u>K20A2 Fuel Rail</u>
$20 Shipped
<u>Acura RSX Type-S Clutch and Flywheel (K20A2)</u>
- From a 2003 with 29,000 miles
- Good condition
$150 Shipped
<u>Acura TSX Clutch and Flywheel(K24A2)</u>
- From a 2004 with 20,000 miles
- Good condition
$125 Shipped
<u>Acura RSX Type-S Valvetrain (K20A2) </u>
- From a 2003 head with 29,000 miles
- Good condition
- Includes retainers, intake valvesprings, and exhaust valvesprings
$125 Shipped
<u>K20A2 Headstuds</u>
- 29,000 miles
- Great condition
$25 Shipped
<u>K24A4 Crank Pulley</u>
-Great condition
$30 Shipped
<u>Honda S2000 Radio/CD Player</u>
-Great working condition
-Lights up amber
-The code is printed on the top
$80 Shipped
<u>EG Civic SI Cluster</u>
-Modified to light up amber
-175k miles
$80 Shipped
<u>1993 LS B18A Throttle Body</u>
- Includes TPS sensor
$45 Shipped
<u>B-Series Hydraulic Speedo Gears </u>
-Great condition, I only have one left
$15 Shipped Each
<u>B-Series Hydraulic Clutch Forks </u>
-Great condition
$15 Shipped Each
<u>USDM ITR/B16 5th Gears</u>
-Great condition, replaced by GSR units
-Set includes countershaft and mainshaft gears
$40 Shipped Each Set
<u>USDM ITR/GSR/B16 1st Gears </u>
-Great condition
$20 Shipped Each
<u>GSR Hydro Differential</u>
-Great condition
-Includes 4.4 ring gear, speedo gear, and bearings
$80 Shipped
<u>B-Series Vtec OBD2 Distributor Housing</u>
-Good condition
-Fits all B16 and GSR heads
$60 Shipped
<u>B-Series Igniter</u>
$30 Shipped
<u>B-Series Passenger Side Axle </u>
-Brand new, not remanufactured!
$110 Shipped
<u>OEM B-Series Cam Gears</u>
-Good condition
$10 Shipped Each Set
<u>B-Series Sensors</u>
-All in Great condition
-Knock sensor isn’t pictured
Knock Sensor - $30 Shipped
TPS Sensor - $30 Shipped
Oil Pressure Sensor - $10 Shipped
Map Sensor - $15 Shipped
<u>Integra Rear Mount</u>
-Works for 92-00 Civic and 94-01 Integra
-Great condition, taken off a 96 GSR
$30 Shipped
<u>Integra Upper Timing Belt Side Mount</u>
- Great Condition
$35 Shipped
<u>90-93 Integra Timing Belt Mount Brackets</u>
-Removed from 90-93 Integra’s
-Both in great condition
$20 Shipped Each
<u>B-Series Timing Belt Tensioners</u>
-All in great working condition with low miles
$25 Shipped Each
<u>B-SeriesTiming Belt Crank Gears</u>
-All gears in great condition
- (2) OBD1
- (1) OBD2
$30 Shipped Each
<u>LS/B16/B20 Windage Tray</u>
-Dirty but not bent or bad
$15 Shipped
<u>(2) B-Series Rear Main Seal Cover</u>
-Good Condition
-One left
$15 Shipped Each
<u>(2) B-Series Rear Breather Boxes</u>
$15 Shipped Each
<u>B-Series Ignition Coils</u>
-Both in good working condition
$15 Shipped Each
<u>Civic VX Exhaust Manifold</u>
-Upper section used for home made turbo kits
-Great condition
30 Shipped
<u>OBD1 SOHC Alternator</u>
-Perfect working condition
-Off my 94 Civic VX, Includes lower aluminum mount
$30 Shipped
<u>OBD1 SOHC Starter</u>
-Off my 94 Civic VX
$30 Shipped
<u>ITR Airbox</u>
-Great condition, includes airbox and filter
$35 Shipped
<u>Koni SS shocks</u>
-Rear for 88 CRX and ITR control arms
-Race valving from Koni to handle higher spring rates that off the shelf Koni’s
-Brand new, never used
$200 Shipped
<u>Civic VX 30/30 Prop Valve </u>
-Great condition
$20 Shipped
<u>1995 GSR Brake Booster</u>
-Perfect condition
$45 Shipped
<u>1995 GSR Brake Master Cylinder</u>
-Good condition
$45 Shipped
<u>2001 GSR Cruise Control Module</u>
$25 Shipped
<u>Walbro 255lph HP In-Tank Fuel Pump</u>
SOLD
<u>2001 GSR Fuel Pump</u>
SOLD
<u>Generic GSR Short Ram Intake</u>
SOLD
<u>Acura RSX Type-S Primary O2 Sensor (K20A2)</u>
SOLD
<u>B-Series Hydro LS Gearset</u>
SOLD
<u>Acura RSX Type-S ECU (K20A2) </u>
SOLD
<u>K20A2 Intake Mani Heatshield</u>
SOLD
<u>Acura RSX Type-S Differential (K20A2)</u>
SOLD
<u>Acura RSX Type-S Power Steering Pump (K20A2)</u>
SOLD
<u>Import Builders I-Beam K24 Rods</u>
SOLD
Modified by Big Teggie at 7:00 PM 3/9/2008
Contact Info
AIM - Dynoair690
-From my 2001 GSR
-RM Ti Retainers
-RLZ Modified LMA’s
-Manley STD Valves
$1350 Shipped
$400 Shipped
$150 Shipped Each
- Great condition
$150 Shipped
$20 Shipped
$20 Shipped
- Good condition
$150 Shipped
- Good condition
$125 Shipped
- Good condition
$125 Shipped
- 29,000 miles
- Great condition
$25 Shipped
-Great condition
$30 Shipped
-Lights up amber
$80 Shipped
-175k miles
$80 Shipped
$45 Shipped
$15 Shipped Each
-Great condition
$15 Shipped Each
-Great condition
$20 Shipped Each
-Great condition
$80 Shipped
-Good condition
$60 Shipped
$30 Shipped
$110 Shipped
-Good condition
$30 Shipped
- Great Condition
$35 Shipped
$20 Shipped Each
$25 Shipped Each
- (2) OBD1
- (1) OBD2
$30 Shipped Each
$15 Shipped
-Good Condition
-One left
$15 Shipped Each
$15 Shipped Each
$15 Shipped Each
-Great condition
30 Shipped
$30 Shipped
-Off my 94 Civic VX
$30 Shipped
<u>ITR Airbox</u>
$35 Shipped
$200 Shipped
-Great condition
$20 Shipped
-Perfect condition
$45 Shipped
-Good condition
$45 Shipped
$25 Shipped
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridracer504 »</TD></TR><TR><TD CLASS="quote">is the distributor obd2a or b???</TD></TR></TABLE>
I don't know, and it doesn't matter.
