brake swap question on a 90 crx hf
Old May 24, 2002 | 10:57 PM
90TegRex's Avatar
Default brake swap question on a 90 crx hf
I'm about to swap in a b18, and discovered that I also need to replace the hubs on the front to use the axles. I planned on replacing the brakes, but I was just wondering two things...
1) If I just do the front brakes, do I have to change the master cylindar and p-valve? (I plan on doing it asap, but I'm on a tight budget)
2) If I have to replace the MC, will the MC from a 90 Integra with abs work? It also has another piece for the abs, but will the MC and booster work without it?
BTW: All of the components, axles, calipers, rotors, etc are comming off of a 90 Acura Integra GS (w/abs).
Thanks for the input
Old May 25, 2002 | 04:48 PM
90TegRex's Avatar
Default Re: brake swap question on a 90 crx hf (davija)
any help here please???
Old May 25, 2002 | 07:58 PM
976's Avatar
976
New User
I believe they will run find together but I cannot be for sure. Try sending this topic into the hybrid fourm - you will get a better response there...
Old May 25, 2002 | 10:08 PM
90TegRex's Avatar
Default Re: brake swap question on a 90 crx hf (w00t!)
will do thanks..
remoer
Feb 16, 2008 04:07 PM
92civicfreak
54
May 26, 2007 09:03 AM
90TegRex
May 26, 2002 07:13 AM
90TegRex
May 25, 2002 08:26 PM
