locked front brakes.
Old Mar 27, 2007 | 12:49 PM
d16efsedan's Avatar
Default locked front brakes.
well today i was driving my car and the front brakes decide to lock up.havent messed with any of the brake components.when i first took off i could feel the brakes drag a little and then they just locked up.i SEARCHED but really didnt find a whole lot.anyone have any idea's what would cause this,also its full on brake fluid...TIA Brian.
Old Mar 27, 2007 | 01:08 PM
d16efsedan's Avatar
Default Re: locked front brakes. (d16efsedan)
Anyone?
Old Mar 27, 2007 | 01:11 PM
civhatch90's Avatar
shouldnt there be some type of return valve on the brakes? if so, that may be your problem.
by what you said im guessing both front wheels locked up so that eliminates the posibility of a bad caliper.
these are just ideas, i dont know anything
Old Mar 27, 2007 | 01:24 PM
Mugencrxsir1's Avatar
Default Re: (civhatch90)
Well when was the last time you changed the calipers? My origional calipers just locked up around the same time about 1.5 years ago. Just went online and picked up rebuilt ones for cheap. The only way to test the caliper is to take it off and try moving the piston, it does'nt take very long to take apart and test....Goodluck
Old Mar 27, 2007 | 01:42 PM
Tyson's Avatar
calipers do sieze. they need to be replaced.
its a good idea to switch both tho, considering if one side is old enough to give you problems the other is probably just as bad.
CRX SHIRTS FOR SALE!
Old Mar 27, 2007 | 05:19 PM
d16efsedan's Avatar
Default Re: locked front brakes. (Tyson)
thanks for the info guys,i went out there and they wasnt seized anymore,i was like wtf.but oh well thanks guys.
Old Mar 27, 2007 | 05:54 PM
Tyson's Avatar
its a good sign you need new brakes.
Old Mar 27, 2007 | 05:57 PM
d16efsedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">its a good sign you need new brakes.</TD></TR></TABLE>yup,well i dont have to worry now 3rd went out in my trans...
JDMPR
Jul 18, 2009 02:09 PM
00fbp
May 23, 2006 03:02 PM
Sprockets
Dec 30, 2002 07:14 PM
eargrub
Aug 30, 2002 02:59 PM
