Help with front brakes
Old Mar 27, 2007 | 11:45 AM
eric416's Avatar
Default Help with front brakes
I'm in the middle of doing front brakes and now i'm at the point where everythings gotta go back together but i cant get the brake piston to go back in. I'm usinging a c-clamp and tightened it as far as it will go and the piston wont budge. I even used a cheater bar to help tighten the clamp. I'd rather not resort to taking it off the car and having to bleed the brakes. Any suggestions?
Old Mar 27, 2007 | 11:46 AM
InvaderTrax's Avatar
If you can't get it in with nothing but your hand turning the clamp, your caliper is forzen. Didn't you make a post the other day saying your car pulls to one side while braking?
Old Mar 27, 2007 | 11:59 AM
esedulerp5tenin's Avatar
Default Re: (InvaderTrax)
take the cap off the fluid reservior to relieve the pressure. make sure you wrap a rag around it incase any comes out, cuz brake fluid eats away at paint
Old Mar 27, 2007 | 12:00 PM
eric416's Avatar
it was about that one side wearing faster than the other one. So its frozen? New caliper that means?
I'm gonna go ahead and try the other side. i hope i don't run into the same problem because that is a brand new caliper. Ill let u know how it goes when im done.
Ohh and the cap is off, didn't help though
Modified by eric416 at 4:27 PM 3/27/2007
Old Mar 27, 2007 | 12:28 PM
eric416's Avatar
Default Re: (eric416)
I finished the other side with no problem. I guess it is frozen and ill have to go get a new one. Thanks guys
Old Mar 27, 2007 | 02:05 PM
blackludevtec's Avatar
jast a thought slacken the the brake flexi hose on the caliper if still does not go back then definatley caliper, if it does then its your flexi hose but this will identify the problem 100%
Berto914
11
Mar 6, 2014 05:27 AM
jdmjoka
Dec 16, 2008 06:31 PM
square_1
16
May 7, 2007 12:01 AM
OneOhNine27
Jan 10, 2007 02:03 PM
pelotudo
Nov 21, 2002 04:41 PM
