I HAVE A QUESTION!!!!
Old Mar 27, 2007 | 10:55 AM
stunnerone23's Avatar
Default I HAVE A QUESTION!!!!
i have a 93 honda del sol si. i had baught a 98 d16y7. im going to use the same head cause its vtec but now i know the head will bolt up and the sensors will to, but will i need obd2 to obd1 wiring kit. i know the these questions will come out.... no i cant use the old block threw a rod the head is still good. i got it dirt cheap not trying to make a race car out of a sohc.
Old Mar 27, 2007 | 10:59 AM
Luserkid's Avatar
Default Re: I HAVE A QUESTION!!!! (stunnerone23)
When you start working on this project youll come to realize your not even touching the harness. With that being said what harness do you think youll be using?
Old Mar 27, 2007 | 12:24 PM
Default Re: I HAVE A QUESTION!!!! (Luserkid)
so that means i can use my p28 ecu..... and i do not need the wiring harness ? the obd2 to obd1
Old Mar 27, 2007 | 12:27 PM
well i know that 96 and up is obd2. but the head is still a 93, so would i need any thing or is it plug and play.....
Old Mar 27, 2007 | 12:32 PM
deadline's Avatar
take the whole z6 head, manifold out and slap it onto the y7 bottom block and dont forget to remove the oil jet from y7 block
Old Mar 27, 2007 | 12:39 PM
deadline's Avatar
Default Re: I HAVE A QUESTION!!!! (deadline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline &raquo;</TD></TR><TR><TD CLASS="quote">take the whole z6 head, manifold out and slap it onto the y7 bottom block and dont forget to remove the oil jet from y7 block</TD></TR></TABLE>you can use the stock wire harness
mudpuppy4life
Jun 25, 2012 06:02 AM
Dnug
Oct 15, 2010 11:56 AM
Whatever
Aug 13, 2008 04:44 PM
HONDA300
Feb 22, 2007 07:29 PM
