.50 over pistons wich ones ?
Old Mar 27, 2007 | 09:36 AM
mtownsi's Avatar
Default .50 over pistons wich ones ?
hey wats up. i got a b17wit ctr pistons took it to the machine shop they measured it cyl walls are taperde. so they bored it .25 over didnt straighten them. so the bored it .50 over. first is that too much or will it be able to handle it ? second i wanted to use oem pistons but they dont make oem pistons .50 over correct ? so now im looking for .50 pistons over that will fit onto my stock rods i found je but they only have them in 10.5-1 compression n i wanted to be alil high then that any1 have any suggestions ok thnks
Old Mar 27, 2007 | 09:56 AM
mtownsi's Avatar
Default Re: .50 over pistons wich ones ? (mtownsi)
and also i have a b16 block so i could take the 1.7 crank , rods and use the ctr pistons in the 1.6 block rite? and wich is stronger the 1.7crank or 1.6 ok thnkas
Old Mar 27, 2007 | 12:07 PM
mtownsi's Avatar
any1 opinons suggestions anything
Old Mar 27, 2007 | 01:22 PM
vtec2nv's Avatar
i think honda does make a .50 over, not a 100% sure.
Old Mar 27, 2007 | 01:49 PM
NUISANCE's Avatar
RSmachines makes pistons in .50 over.
Old Mar 27, 2007 | 02:14 PM
mtownsi's Avatar
ok but is .50 over too much or wat ? thats wat im really worried bout i dont want to be racing it and the cyl wall crack ya know
Old Mar 27, 2007 | 02:22 PM
spun Vtec's Avatar
Default Re: (mtownsi)
Im running .50mm oversized OEM honda pistons on my motor now. d16z6, d16a1 pistons.
Old Mar 27, 2007 | 04:26 PM
mtownsi's Avatar
bump bump
Old Mar 27, 2007 | 04:51 PM
eg714's Avatar
im running top line p73 pistons .50 over in my ls block for 2 years now with many abuse and its still holding up
Modified by eg714 at 9:46 PM 3/27/2007
Old Mar 28, 2007 | 04:06 AM
mtownsi's Avatar
bump bump i need more feedback my motor is in the machine shop now so idk wat i should do wit it
Old Mar 28, 2007 | 06:49 AM
RPRacing's Avatar
81.5mm is fine to run daily. i've run 82mm with no problems.
Wiseco makes an 81.5mm 8.25cc piston. Part # is k593M815.
1993gsrcivic
Nov 14, 2007 08:11 AM
veilsides2000
May 13, 2006 01:22 PM
Watkinsm3
Apr 9, 2003 09:57 AM
RosebloodSol
Feb 15, 2002 05:20 PM
