blox rear lower control arm?
Old Mar 27, 2007 | 09:29 AM
o_no_vtec's Avatar
Default blox rear lower control arm?
any good? would you recommend?
Old Mar 27, 2007 | 10:44 AM
instrument's Avatar
it's a lower control arm.
there's not really a good or bad here
they are only for looks, so if you like they way they look their good.
Old Mar 27, 2007 | 11:19 AM
schpiel's Avatar
I have a set on my sedan, and my buddy has them on his hatch. Have held up fine. Just like instrument said, they are mainly for looks. Weaskauce has them at a good price.
Old Mar 27, 2007 | 11:49 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (schpiel)
make sure you clock/preload the bushings when you install, or your bushings will last a month.
Old Mar 27, 2007 | 01:11 PM
usdmEHboy's Avatar
Default Re: (B serious)
You guys are all wrong..lower control arms are needed if you want to run an aftermarket sway bar/ subframe brace combo...yes the blox lower control arms are fine but you don't really need them unless your running some kind of set up like i mentioned
Old Mar 27, 2007 | 01:30 PM
Chim Chim's Avatar
Default Re: (usdmEHboy)
The only exception to that would be if you have stock LCAs with a pre-drilled hole for you to mount a stock type endlink into like the 96-00 civics. 92-95 civics have two different LCAs listed in the parts manual, one with a provision for a rear sway, the other, without...
For example, if you have a 96-00 civic and would like the try out the ITR rear sway ASR subframe brace combo, rear LCA's are not entirely necessary...
1996 civic LX/DX/CX/EX 52350-S04-000
1999-2000 civic SI 52350-S04-000
Old Mar 27, 2007 | 02:32 PM
blinx9900's Avatar
Default Re: (Chim Chim)
SUCKS! my bushing cracked after a few months on my blox no i didnt install them with preload but come on, a few months!
HastyPrawn
Suspension & Brakes
11
Mar 7, 2014 08:20 PM
D15B Civic
Suspension & Brakes
11
Apr 30, 2010 10:47 AM
Crimson_Tide
11
Jul 11, 2005 05:57 PM
andyvaj
Mar 1, 2005 12:12 PM
