Rotors???
Old Mar 27, 2007 | 04:48 AM
Fatcobra's Avatar
Default Rotors???
When i go to brake there is a squeaking come out of my wheel... i just changed the brake pads but i am thinking it is the rotor. could it be anything else?? it is only when i press on the brake.
Old Mar 27, 2007 | 11:45 AM
BlueIntegraBoy's Avatar
Default Re: Rotors??? (Fatcobra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbible.com &raquo;</TD></TR><TR><TD CLASS="quote">Brake squeal.
Squealing brakes are a sign of one of two things : the friction material is all gone and you're jamming the backing plate against the brake rotor, or the fit of the brake pad against the caliper piston isn't as snug as it could be. Either way, the squealing is the result of an extremely high-frequency vibration between the pad, the caliper piston and the brake rotor. Some vehicles have problems with squealy brakes right from the factory. In those cases, simply changing brake pad manufacturer can often cure the problem as the different pads will have a slightly different harmonic frequency, which is harder to attain.
A good way to solve brake squeal is to put some copper-based grease on the back of your brake pads. That's very important so I'll say it again in CAPS : THE BACK. Copper grease is extremely resistant to pressure and heat and if you get any on the front of your pads, you'll need new pads and rotors or discs. The picture here shows a cutaway of a disc brake assembly. The blue caliper housing on the right is missing to show the two silver brake pistons. The idea is that it creates a small pocket of sticky lubrication between the front side of the brake pistons and the back side of the brake pads. This is usually enough to prevent the high-frequency squeal.
They sell anti-squeal glue thing at automotive parts stores.
user 93082343
14
Mar 23, 2009 02:49 PM
Tutin77
Sep 18, 2004 09:42 AM
Ninja Mike
May 27, 2004 07:20 PM
apexinghonda
45
May 27, 2004 07:02 PM
