RPM/speed SI d16 sohc
Old Mar 27, 2007 | 03:51 AM
Groove_D's Avatar
Default RPM/speed SI d16 sohc
I have a problem with my gauges, i took them apart and when i put the needles back i have a feeling that my speed doesn't give me the proper reading.
Can someone tell me when you doing 60 km/h in 3rd gear what rpm does it read?
Its the 1.6 SOHC vtec.
And does anyone know what is the proper way to reset the gauges?
Thanks.
Old Mar 27, 2007 | 02:09 PM
Groove_D's Avatar
Default Re: RPM/speed SI d16 sohc (Groove_D)
Anyone?
Old Mar 27, 2007 | 02:44 PM
95hatchcivic's Avatar
I will check for you when i go take my car out
Old Mar 27, 2007 | 03:21 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Groove_D &raquo;</TD></TR><TR><TD CLASS="quote">I have a problem with my gauges, i took them apart and when i put the needles back i have a feeling that my speed doesn't give me the proper reading.
Thanks.</TD></TR></TABLE>
lol thats a random *** speed/gear reading. 60km/h in 3rd??? How bout 100km/h (around 60mph) in 5th....thats more standardized. You're lookin at about 3k -3200 rpm in 5th at 60mph. IF you have the D16Z6 (92-95). If you have a del sol with a y8, im not sure. You didnt say what car/year Si you have.
Old Mar 27, 2007 | 08:15 PM
Groove_D's Avatar
Default Re: RPM/speed SI d16 sohc (B serious)
It's a 93 del sol SI.
Although year shouldn't matter since i mentionned the engine.
Old Mar 27, 2007 | 09:45 PM
B serious's Avatar
yes but the del sol was offered with a D16Z6 and a D16Y8 depending on the year. Im not sure about the Y8 gearing, like i said.
Old Mar 27, 2007 | 09:50 PM
Nongan's Avatar
y8 and z6 are gearing are identical if i remember right. the only difference is the shift forks i think.
Old Mar 27, 2007 | 10:08 PM
DaveSi677's Avatar
100 km/h in 5th you should be around 2500 or 2600 rpm.
Old Mar 27, 2007 | 10:10 PM
B serious's Avatar
Default Re: RPM/speed SI d16 sohc (DaveSi677)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveSi677 &raquo;</TD></TR><TR><TD CLASS="quote">100 km/h in 5th you should be around 2500 or 2600 rpm.</TD></TR></TABLE>
in an SI?!! you canadians have some weird gearing then. That sounds like DX gearing to me.
Old Mar 28, 2007 | 04:32 AM
Groove_D's Avatar
Ok i'll compare. 2500-2600 seems a bit low though. Anybody else?
Old Mar 28, 2007 | 07:25 AM
DaveSi677's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">
in an SI?!! you canadians have some weird gearing then. That sounds like DX gearing to me.</TD></TR></TABLE>
Yare thinking of a B16 Si which to us is the SIR. Also I have a 93 Si hatch with Y8 head and Z6 bottom with a Y8 tranny but I also had a Z6 tranny before. So at a 100 km/h you should be around 2500-2600 rpm and at 110 you should be at around 2800-2900 rpm. If you are doing 60 km/h in 5th you should be around 1500 to 1600 rpm.
Old Mar 28, 2007 | 07:36 AM
.Sarge.'s Avatar
If the Tranny is an S20 (civic ex, Del sol Si) then you should be right at 2950RPM if your going 60kph(37.2mph)
Old Mar 28, 2007 | 09:08 AM
B serious's Avatar
Yare thinking of a B16 Si which to us is the SIR. Also I have a 93 Si hatch with Y8 head and Z6 bottom with a Y8 tranny but I also had a Z6 tranny before. So at a 100 km/h you should be around 2500-2600 rpm and at 110 you should be at around 2800-2900 rpm. If you are doing 60 km/h in 5th you should be around 1500 to 1600 rpm. </TD></TR></TABLE>
No, im talking about the SOHC si. I had one of those motors in my hatchback. It came out of a 93 Si. This was a USDM car that was manufactured in japan. Im not sure if the Canadian cars are different. If you have the Y8 trans from a civic EX, this could mean the difference as well.
The 93 SOHC Si trans will be around 3k-3200 rpm at 60mph (100kmh) in 5th.
Old Mar 28, 2007 | 03:19 PM
Groove_D's Avatar
Default Re: RPM/speed SI d16 sohc (_.Sarge._)
Wow, i get different numbers here. It's not sir, i stated that. It's SOHC 1.6 vtec.
Thanks for the replies so far.
Old Mar 28, 2007 | 04:13 PM
Bense's Avatar
use a gear calc from the tech/misc stickied faq.
ratios cause i'm nice
1st = 3.25
2nd = 1.909 or 1.9
3rd = 1.25
4th = 0.909
5th = 0.703
final drive = 4.25
Old Mar 28, 2007 | 08:52 PM
DaveSi677's Avatar
Thanks Bense in being so nice in giving us the gear ratios. I used the gear/speed/rpm calculator and I guess I was right. At 60 mph(100km/h) you would be doing 2600 rpms.
RPM 1st 2nd 3rd 4th 5th
500 2 4 6 9 11
600 3 5 8 10 14
700 3 6 9 12 16
800 4 7 10 14 18
900 4 7 11 16 20
1000 5 8 13 17 23
1100 5 9 14 19 25
1200 6 10 15 21 27
1300 6 11 17 23 29
1400 7 12 18 24 32
1500 7 12 19 26 34
1600 8 13 20 28 36
1700 8 14 22 30 38
1800 9 15 23 31 41
1900 9 16 24 33 43
2000 10 17 25 35 45
2100 10 17 27 37 47
2200 11 18 28 38 50
2300 11 19 29 40 52
2400 12 20 30 42 54
2500 12 21 32 44 56
2600 13 22 33 45 59
2700 13 22 34 47 61
2800 14 23 36 49 63
2900 14 24 37 51 65
3000 15 25 38 52 68
3100 15 26 39 54 70
3200 16 27 41 56 72
3300 16 27 42 58 75
3400 17 28 43 59 77
3500 17 29 44 61 79
3600 18 30 46 63 81
Old Mar 28, 2007 | 09:13 PM
sageuvagony's Avatar
damn... I thought the rpms would be lower in 5th gear with a stick... Is it not that much different than an auto? I'm doing a auto to manual conversion as we speak... I have a DX tranny unfortunately... so the gearing is longer right? My moms camry could do 60pmh in 4th gear at 2,000 rpms. My civic auto was at around 2,500 or a lil more going 60 in 4th gear... Is there a big difference in gas savings between auto and stick?
Old Mar 28, 2007 | 09:18 PM
DaveSi677's Avatar
Default Re: (sageuvagony)
Yes of course it make a difference in fuel economy.
Old Mar 29, 2007 | 08:36 AM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveSi677 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks Bense in being so nice in giving us the gear ratios. I used the gear/speed/rpm calculator and I guess I was right. At 60 mph(100km/h) you would be doing 2600 rpms.
Well you have a different trans then. The trans attached to the D16Z6 in the U.S. will put you around 3k rpm at 60mph
Old Mar 29, 2007 | 05:40 PM
DaveSi677's Avatar
Well you have a different trans then. The trans attached to the D16Z6 in the U.S. will put you around 3k rpm at 60mph</TD></TR></TABLE>
Are you retarded? I just did you the calculation for a Z6/Y8 tranny with the gear ratio's and final drive numbers that Bense gave.
Old Mar 30, 2007 | 09:38 AM
B serious's Avatar
lol why would you call me retarded? What if I really was? and what if those gear ratios werent right on....or you were wrong on a calculation?
I said that the USDM D16Z6 that i posessed was at around 3k at 60mph. I never said you were wrong, douche bag.
Then i said that "you must have a different trans", and you come out and call me retarded? Get hooked on phonics, then kill yourself.
Old Mar 30, 2007 | 02:13 PM
Groove_D's Avatar
Thanks for the help.
Old Mar 30, 2007 | 06:11 PM
Groove_D's Avatar
According to this, i am at the right rpm at 60 mph in 5th gear, which is in between 2600-2700. But when i'm doing 40 mph in the 3rd the rpm gauge according to this table should read 3100. In my case it reads 2500-2600.
Something is messed up. Either i have a different gear ratio or my speedo or rpm gauge is messed up.
Does anyone know how to reset these gauges?
Old Mar 31, 2007 | 07:38 AM
DaveSi677's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">lol why would you call me retarded? What if I really was? and what if those gear ratios werent right on....or you were wrong on a calculation?
Then i said that "you must have a different trans", and you come out and call me retarded? Get hooked on phonics, then kill yourself. </TD></TR></TABLE>
Ok Bense, who is the transmission guru on HT, gave us the gear ratio for our transmission with the final drive. All I did was copy paste the numbers on a website which does the calculations for you. How could I make a mistake with that? Are you questioning Bense on his numbers? Because between you and me, he knows more then all HT put together when it comes to this stuff. That is why he didn't give you guys a strait answer, he gave you the numbers and wanted you to figure it out! Also did you ever think maybe you have a different transmission then what you are suppose to have? Also Canadians didn't get anything different from the US when it came to engines or transmission!
I need hooked on phonics hahahaha, ya I think you should use your spell check once in a while and maybe relearn your grammar but nice one asshat! Also you are the one acting like a douche bag because you don't want to admit your wrong after I proved it to you! Whatever think what you want, your the one that look like the idiot giving out false information!
Old Apr 2, 2007 | 10:14 AM
B serious's Avatar
I need hooked on phonics hahahaha, ya I think you should use your spell check once in a while and maybe relearn your grammar but nice one asshat! Also you are the one acting like a douche bag because you don't want to admit your wrong after I proved it to you! Whatever think what you want, your the one that look like the idiot giving out false information!</TD></TR></TABLE>
lol dude take a pill.
I never claimed you were wrong.
I said maybe you had a DIFFERENT transmission. Look up the word "different" in a dictionary. "you might have a DIFFERENT trans" doesnt mean "you were wrong, I was right."
I never said anything about right or wrong.
You should check your grammar once in a while as well. "your the one that look like an idiot giving out false information"
Thats TWO errors, since we're nit-picking. Thats not even mentioning the other errors found in your message. Damn...you should get your **** proofread, huh? Maybe take an English class...since we speak that language here.
What a moron.
