Wiseco ceramic coated p/w clearance
I'm rebuilding my type r block with Wiseco 81.50 mm. ceramic coated pistons for a roadrace application.
The standard Wiseco's have a recommended piston to cylinder wall clearance of 0.0030-0.0033.
Should the ceramic coated pistons run tighter due to the less thermal expansion?
Modified by paulITR at 12:18 PM 3/27/2007
basicly the ceramic coating on the tops of the pistons will burn off over time, so if you run it tighter it will be fine till the coating burns off, then its going to be too tight. we typically run the pistons a little looser than that, especially for a RR application where the stuff is going to see alot of abuse. the moly coating on the sides will wear off very quickly as well, so its best to build the motor as if those coatings arent there.
On a RR app, I would go with .0033 to .0035. If it were a drag race motor only, I would go with .0030. When RRing the pistons will see heat for longer periods of time and will expand more than anticipated some times...
Now i'm confused about how much p/w clearance to set since the sheet which came with the pistons recommendes 0.0025 for the ceramic coated.
Is that a clearance that works until the coating burns off only?
And how long is the coating suppose to last?
The Wiseco spec sheet reports the .0025 clearance only without separate between a drag or different application.
It's very tight compared to the clearance suggested in this discussion but if i want to give credence to Wiseco it should be fine at least till the coating burns off.
But how many miles will it last?
I'm scratching my head.......
I'm in for the same dilema for road race too.
I got some wiseco 81mm for a friends B16A and spec sheet says the same 0.0025. But we are going for 0.003 min as this engine will be living in 7000-9500rpm most of the time.
I got another set wiseco 85mm that calls for 0.004 which is pretty loose to me. This set we are also deciding to go for wiseco spec at 0.004 or a loose 0.0045.
Anyone?
Anyone?
prostreetonline
Jul 20, 2004 11:21 AM
turbo Si
Jun 28, 2002 12:00 PM
