LSVTEC build
heres some pics of progress up to date on an LSVTEC build i currently am doing for a guy. everyone loves pics of goodies.
fresh block from machine shop , bored to 81.5mm.
head and cams and such , OBD1 PR3 head.
the goodies going into the guts
everything cleaned , bearnings lubed , installed , crank sitting in place
YS1 tranny going on
crank torqued in , couple brackets on , water and oil pumps installed , new front and rear main seals
breather box , water pipe , sandwich plate installed
fresh holes
test fit of golden eagle headstuds and headgasket
plug removed from head , fitting installed as well as oil line
more to come!! waiting on 11.5:1 moly coated skirt pistons to arrive via priority mail , lol. were planning on chipping his virgin OBD1 PR3 and tuning with crome. running ITR basemap , go from there. anyone have any insight or suggestions or questions for that matter , love to hear or answer them.
YS1 tranny going on
fresh holes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">You finished boring and honing it without pistons? What is the skirt clearance? </TD></TR></TABLE>
exactly what i was thinking.... why would you do a final bore/hone when you dont know what the pistons measure out to?
the customer changed his mind , he was gonna run 81.5 B1 pistons in it only. once we got the engine back , since a deal came around per say on pistons , he decided he wanted to go all out. i cant forsee a problem with clearance. people beleve in and run many different piston to cylinder clearance. see what it looks like once both sets of pistons are compared is all we can do. there both 81.5mm bore pistons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready »</TD></TR><TR><TD CLASS="quote"> i cant forsee a problem with clearance. </TD></TR></TABLE>
Thats because you are not psychic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready »</TD></TR><TR><TD CLASS="quote">people beleve in and run many different piston to cylinder clearance. </TD></TR></TABLE>
People also blow motors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready »</TD></TR><TR><TD CLASS="quote"> there both 81.5mm bore pistons. </TD></TR></TABLE> One could be 81.497 and the other could be 81.4965. Which would you run?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption »</TD></TR><TR><TD CLASS="quote">
One could be 81.497 and the other could be 81.4965. Which would you run?</TD></TR></TABLE>
whats with the being a dick and talking condensending exactly? im just trying to post some pics , have run , share stuff , i dont need your grief. i also dont have to prove anything to you. why be a dick , read the story and look at the pics man , simple. ill take care of the rest. if you got nothing nice to say , say nothing.
sorry , i just dont see where that came from exactly or why it was warranted.
Because DonF brought up valid points and questions and you didnt answer them, you just rattled off some gibberish. "People believe in different things". What does have to do with the actual piston to wall clearance on THIS build?
for one thing , if he had of read it all instead of just talking he would see that i said before , at the start , i didnt clearance the block so how am i supposed to know. the block came with pistons fitted to the holes of course , like i also said before. therefore i dont understand his comments. it was brought to me done by a machine shop already. were waiting for pistons to arrive to see how they compare , i dont understand whats unclear or wrong about this?
engine is assembled and running great , will have pics to finish this thread off as soon as i get them from the guy. went great , zero leaks. love it when **** goes smooth. we had a problem with the ebay dude that sold us the pistons , he fuked us and we still havent seen them yet , 2 months later almost. so its running the PR4 pistons the engine was sized for , for now.
EDIT:
here ya go boys , the finish pics:
head torqued on
good coat of oil on cam and head journals , cams sitting in place with caps and holders also sitting in place ready for torque , youl notice when sitting cams in head to tighten , youl find a spot where each cam is in total relief , not pushing on any valves , this is best place to find when tightening them in. where the arrows point at this time doesnt matter , just make sure no pistons are at TDC , just in case.
almost done , lol
timing belt installed now , notice marks
good ol redtop on after refinishing
oilpan on and tight
having a smoke tightening somin , lol , looks like tensioner
flywheel next with engine sitting on ground now off stand
[IMGhttp://i83.photobucket.com/albums/j295/blacksun_photos/dougs/dougs51.jpg[/IMG]
than clutch
YS1 tranny on and tight
new knock sensor location youl notice , oil pressure sensor and sandwich adapter , getting ready to hook up oil line for good. knock sensor is bigger round one
engine hanging on my new hoist ready for insertion
almost ready , lol
passenger side mount first
than lower drivers side in
few month old dizzy installed , with new 9mm NGK wires and new iridium plugs as well
ready for axles and front and back mounts now
fill tranny and engine , notice my home made tranny fill tool from rubber garden hose and old cherry can spout , haha.
2 shots of it done and sitting pretty and running , notice also , the header missing in the last pic , last minute change cause the header didnt fit the car quite good , was an LS header and it doesnt fit the oil pan well and its too long for the midpipe. his exhaust is kinda wrote anyways , hes looking at new one. anyways enjoy guys , was a fun little project , and my first LSVTEC build. although im sure it wont be the last , lol.
Modified by blackKready at 8:26 PM 5/2/2007
EDIT:
head torqued on
almost done , lol
oilpan on and tight
than clutch
almost ready , lol
