the b18c has pms every other day, wtf is goin on?
Old May 24, 2002 | 09:01 PM
hybrider's Avatar
Default the b18c has pms every other day, wtf is goin on?
day time the car will run like ***, once the sun goes down, it starts to run as it should
now wtf could cause such a loss of power during the day? i mean the differences are huge once nightfall comes around
anyone?
Old May 24, 2002 | 09:16 PM
kurt.'s Avatar
Default Re: the b18c has pms every other day, wtf is goin on? (hybrider93)
Is it temperature related maybe?
Old May 24, 2002 | 09:26 PM
hybrider's Avatar
Default Re: the b18c has pms every other day, wtf is goin on? (Vantage)
well when we swapped it in, we had a small problem with the fan coming on, so we hooked it up to where it comes one once the key is in the ignition
anyone?
Old May 24, 2002 | 09:43 PM
mugenracer's Avatar
if it comes on just when the key is in the ignition, doesnt that mean its running every time you drive the car??? Did you ever feel the hot air coming off those things, no wonder your cars down on power!
Old May 25, 2002 | 08:59 AM
hybrider's Avatar
Default Re: the b18c has pms every other day, wtf is goin on? (mugenracer)
how much of a diff/power loss can this cause?
Old May 25, 2002 | 11:14 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
you've observed how much
Old May 25, 2002 | 02:03 PM
hybrider's Avatar
Default Re: the b18c has pms every other day, wtf is goin on? (dLo GSR)
so you guys think its the fan and the way we set it up is the cause? God i hope so
on to fix it
Old May 25, 2002 | 04:31 PM
SpoolinEK's Avatar
my friend did the same thign to his radiator fan...it runs perfectly fine like that..it could be somethign else.
Old May 25, 2002 | 07:33 PM
hybrider's Avatar
Default Re: the b18c has pms every other day, wtf is goin on? (EG Civic)
fudge :/ not sounding good
anyone else?
Old May 26, 2002 | 09:58 AM
hybrider's Avatar
Old May 26, 2002 | 10:07 AM
Rocket's Avatar
Your car is a Vampire.
Seriously, most cars run better at night. You might be running slightly rich in the daytime and at night your hitting the Air Fuel sweet spot.
How does the exhaust tone sound in the Day vs. at Night? Back in the old days pro-drag guys tuned soley by ear and this still is valid first pass method.
Old May 26, 2002 | 10:58 AM
hybrider's Avatar
Default Re: the b18c has pms every other day, wtf is goin on? (Rocket)
of course most cars run better at night, but im talking about a night and day difference, oh and btw.....that doesnt mean i run correctly every night, but most the time when the sun is down it will run how it should, but not every time....
im running rich regardless (mugen ecu) but even with the old p72 i still had the same problems
Old May 26, 2002 | 02:27 PM
hybrider's Avatar
anyone? :sigh:
Old May 26, 2002 | 04:15 PM
Rocket's Avatar
Well if you are running rich with the mugen program you may want to take a look at your plugs. If they are sooty then you are running too rich. Having a rich situation will exaggerate your night/day performance.
Old May 27, 2002 | 02:34 PM
hybrider's Avatar
again even with the p72, same thing :/
Old May 27, 2002 | 06:43 PM
Rocket's Avatar
Are all your sensor hooked up? Like the IAT sensor or or the coolant temperature sensor?
cpierich
Feb 26, 2012 06:27 PM
95silverluder
Sep 19, 2007 04:42 AM
InvaderTrax
May 13, 2007 05:59 AM
Ideal
Oct 25, 2002 07:35 AM
