obd0 to obd1 conversion no spark
Old Mar 26, 2007 | 07:24 PM
954dooreg's Avatar
Default obd0 to obd1 conversion no spark
hey i have a 91 Honda with a mini-me i just did a obd0 to obd1 conversion on my car i bought my harness from eBay i wired every thing up like it suppose to be and i still don't get spark i checked every ground swapped out main relay and tried the distributer on another car and it works fine any help would be greatly appreciated thank you
Old Mar 26, 2007 | 09:10 PM
E_F_9's Avatar
Its a obd1 dizzy right?
Old Mar 26, 2007 | 10:59 PM
91 ef hatchback's Avatar
Default Re: (E_F_9)
yes it is a obd1 dizzy
Old Mar 26, 2007 | 11:05 PM
crx_si-r's Avatar
Default Re: (91 ef hatchback)
did u make a dizzy adapter plug? or repin?
Old Mar 27, 2007 | 08:49 AM
dephtone's Avatar
There are 2 black wires on the conversion harness that each go into black wires on the dizzy plug. I had the same problem where my car would not start either, I just switched the black wires. There is no way to tell them apart. These wires go into the OBD0 dizzy plug.
Hope this isn't confusing.
Old Mar 27, 2007 | 11:16 PM
Default Re: (dephtone)
the harness is from eBay the obd1 dizzy is has the connectors that plugs into it wired to the obd0 harness. The first connector goes org/blu>org/blu, org>org, w/blu>w/blu, w>w, thick white> yellow green, c1 on the ecu>blue green, c2 on the ecu to blue yellow. the second connector is wired blk/y>blk/y, blue>blue. Is that the correct way to wire it?
Old Mar 27, 2007 | 11:20 PM
cr-x-91's Avatar
so the dizzy is from a z6 correct...and u got the right piggy back harness for the dizzy.check timing and how did u check for spark?
Old Mar 27, 2007 | 11:29 PM
Default Re: (cr-x-91)
yea, put a plug in cyl 1 wire and put the plug to the car. no spark
Old Mar 27, 2007 | 11:43 PM
cr-x-91's Avatar
did u by a chance hook up cel switch of some sort..so u can tell what codes u have...theres a way to hook it so it blinks on ur cel (check engine light)
Old Mar 27, 2007 | 11:56 PM
yea i have it on the wire harness it is a black and yellow wire
Old Mar 28, 2007 | 09:41 AM
cr-x-91's Avatar
than hook it up and c what codes u get..
Old Mar 28, 2007 | 10:46 AM
wickedEFguy's Avatar
Hope that helps
Old Apr 9, 2008 | 06:51 PM
tacorunner87's Avatar
Default Re: (wickedEFguy)
I pretty much having the same issue. I bought my harness off ebay also, What you guys are saying about the blacks for grounds, on mine theres 2 blacks 1 brown all grounds, one goes the the service check signal, VRM( dont know what this is) and O2 sensor green. Nothing going to the dizzy?
Old Apr 9, 2008 | 07:27 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (tacorunner87)
See the chart above for how to re-pin the dizzy.
Old Apr 9, 2008 | 07:45 PM
Default Re: (mar778c)
ya my dizzy harness is wired exactly the same
Old Apr 10, 2008 | 01:26 PM
jdmhondamotive's Avatar
Default Re:
im having the same problem only im getting spark but im still getting a code 8...what i did to fix the problem with dizzy is i wired it straight to the jumper harness to elimanate any possibilities of a problem being in the wiring harness. you may want to try that gL.
Old Apr 10, 2008 | 02:35 PM
Default Re: Re: (jdmhondamotive)
I just depinned the dizzy harness still get no spark, Think it could be my harness i got from ebay?
Old Apr 10, 2008 | 05:25 PM
vtec93accord's Avatar
Im having a similar problem but mine is with the Crank Position Sensor, i cant get it to go away period. Not trying to thread jack at all but does anybody know where to pin the 2 wires for the crank position sensor?
I think your problem is definetly wiring related.
Old Apr 10, 2008 | 05:36 PM
Default Re: (vtec93accord)
I checked the wiring i had 2 wires off on the dizzy harness, I get a check engine light of 9 blinks looked it up and it says cylinder 1 position sensor? could that be the vrm on my instructions?
this thread is over a year old i just brought it back to life.
Old Apr 10, 2008 | 05:52 PM
I dont think that has to do anything with the cylinder position sensor if you ask me. On mine, all i had to do with something for the dizzy was pin the CKP sensor, i pinned it at B10 and B12 like it said and its still throwing a code 4. Dizzy has been replaced also and wiring is good all they way to the ecu pin so i dont think i have the correct pin locations
Old Apr 10, 2008 | 05:57 PM
Im thinking i may end up buying a rywire harness. think i lost my money on the one i bought on ebay. the seller will not respond to my questions
Old Apr 10, 2008 | 07:14 PM
Yea im using a rywire conversion harness. Its nice, i will prolly give them a call and see what they say about my problem.
Old Apr 10, 2008 | 07:33 PM
You may hit them up on here there very helpful. they have tried to help me and id didnt buy my harness through them. but im really thinking about it
ok i have a p75 ecu, ebay harness, repinned the dizzy plug, and td-55u dizzy. doing som e research online to see if my ecu is obd1 or obd2 since p75 can be both, are obd1 and obd2 ecu plugs the same just pin out is different? Also
Old Apr 10, 2008 | 08:13 PM
Well you need to figure out if your specific ECU is obd 1 or 2. Once you do that your straight and you can get the correct pinouts on here somewhere.
I guess ill hit them up on here and see what they say about it.
Old Apr 10, 2008 | 11:03 PM
cool my ecu is obd1 but i think my dizzy is bad. i get no spark it gets really hot(were you cant even touch it), it wiggles when its mounted on the car like the shaft is bent,
