can BMW HID headlight projectors be made to fit DC2 R ?
Old May 24, 2002 | 08:39 PM
Anderson's Avatar
Default can BMW HID headlight projectors be made to fit DC2 R ?
can this work?
i'm wondeirng if this is possible?
i'm not talking about just the HID kit. but the BMW projector unit with HID??
Old May 24, 2002 | 09:12 PM
B2FiNiTY's Avatar
Default Re: can BMW HID headlight projectors be made to fit DC2 R ? (Anderson)
It will fit but it will take some work I believe... I have seen it done on 98+ accords.
Old May 24, 2002 | 09:32 PM
Anderson's Avatar
Default Re: can BMW HID headlight projectors be made to fit DC2 R ? (B2FiNiTY)
hey B2 do you have a pic of that?
have you seem a converstion on the dc2r?
is the bmw projector the same size as the dc2?
Old May 24, 2002 | 11:18 PM
jw's Avatar
jw
Yeah, it's not hard at all. You don't need the projector unit. Just gut out the bulb and ballest. Modify the bulb to fit the stock headlamp and that's it. When you're done, it'll look something like this:
Old May 24, 2002 | 11:45 PM
uNF$@#!'s Avatar
Default Re: can BMW HID headlight projectors be made to fit DC2 R ? (jw)
why bother? brand new phillips 6000k ultinon kits can be had for 430 shipped...
Old May 25, 2002 | 05:02 AM
MTK Kommander's Avatar
Default Re: can BMW HID headlight projectors be made to fit DC2 R ? (00-0187)
because the BMW projectors will be made for HID.. putting HID into halogen housings is gay..the lighting is ****..and it blinds everyone.. ..the only problem you might have with the conversion is that the HID projectors are smaller in size compared to the integra projectors..unless you have the ITR HID headlights..then it will be the same.. but the BMW beam patters will be correct for USA driving..the JDM ones are made for right hand drive..
Old May 25, 2002 | 05:28 AM
Edwin's Avatar
Default Re: can BMW HID headlight projectors be made to fit DC2 R ? (MTK Kommander)
The Integra housing is an exception it has a projector and it distributes the light properly when placing HID bulbs.
D2S bulbs with a 9006 base is all you need + ballasts is all you need.
It those dumb f*cks who put D2R bulbs in projector housings or put HIDs reflective housings not designed for HID use. ie. EK Civics Light is scattered everywhere, and it looks like they are highbeaming everyone.
Old May 25, 2002 | 06:43 AM
BABY NSX's Avatar
Default Re: can BMW HID headlight projectors be made to fit DC2 R ? (Edwin)
Edwin,
Can you take some clossup shots or your modified 9006/DS2 bulbs. I have a kit here that I need to modify and would like to see how others have done the mod.
Thanks bud!
Old May 25, 2002 | 06:16 PM
JohnnyBoy's Avatar
Default Re: can BMW HID headlight projectors be made to fit DC2 R ? (BABY NSX)
Doug, I tried E-mailing you some pics....but it won't let me.....I'll see if I can post them somewhere....
Old May 25, 2002 | 06:55 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I think Audi HID projectors (S4, etc.) have the same physical exterior shape as Integra projector housings... if so it should be a direct swap.
Old May 25, 2002 | 07:13 PM
BABY NSX's Avatar
Default Re: can BMW HID headlight projectors be made to fit DC2 R ? (JohnnyBoy)
Sure thing, I got a notice of it. I haven't run into that before so I'll have to look into why.
Thanks in advance!
Old May 27, 2002 | 02:32 PM
t's Avatar
t
Default Re: can BMW HID headlight projectors be made to fit DC2 R ? (PatrickGSR94)
LOL! Make sure you know where they have your stock lights (in stock) before you start your project.
Old May 28, 2002 | 03:12 AM
JohnnyBoy's Avatar
Default Re: can BMW HID headlight projectors be made to fit DC2 R ? (t)
Farthest thing from a "direct swap"......Not to be a dick BUT..... If you have no idea what is involved or have never done it why comment on it?
Old May 28, 2002 | 09:21 AM
Anderson's Avatar
so is it possible?
Old May 28, 2002 | 09:25 AM
Keane Rated R's Avatar
so is it possible?
I´m also interested, and what´s the BMW part number needed?
Old May 28, 2002 | 09:31 AM
AoiGSR's Avatar
25 Year Member
"putting HID into halogen housings is gay" ownz
I think it's aoight
-aoib0t, who thinks the HIDS dun blind anyone, but not sure.
Old May 28, 2002 | 09:40 AM
Community Builder
Well I took apart my headlights a couple months ago to clean out the moisture. I can't remember exactly what the projector housings looked like, but I think they were pretty similar to the ones that I saw on a post in the Sylvania Lighting forum, where a guy took 99-00 Civic projector headlights and swapped in Audi S4 projectors. The shape of the S4 HID projector and the projector used in the Civic headlight looked the same. These projectors looked larger than the normal projectors used in most aftermarket Civic headlights (the crappy ones), so I had assumed they were similar to Integra projectors.
Old May 28, 2002 | 12:21 PM
98ITR#0020's Avatar
I had the BMW headlights in my car before someone hit me, and it only took like 10 minutes each. they are a bitch to aim but, who cares? thats what high beams are for. I got them for pretty much nothing because my friend works for BMW.
Old May 29, 2002 | 12:35 PM
Anderson's Avatar
Default Re: can BMW HID headlight projectors be made to fit DC2 R ? (98ITR#0020)
u got pics of this conversion?
Old Jun 3, 2002 | 03:56 PM
2qwik2nv's Avatar
Edwin, it's Scott, from the meet last Thursday. ITR with graphics...anyways, where could I pick up ballasts for a decent price, I'm assuming Johnny could get them but I'd be paying through the roof. Any ideas? I'd be looking for mainly the ballasts and the bulbs I can find almost anywhere.
Old Jun 3, 2002 | 05:37 PM
Edwin's Avatar
Default Re: can BMW HID headlight projectors be made to fit DC2 R ? (2qwik2nv)
Your best bet is either go with local guys xeondepot.ca or Trevor (visual dynamics). Trevor mentioned he is going to holding a groupbuy again. $400 US for the bolt on set no modification. This would be the way to go.
Dremel modification of OEM D2S bulbs with sanding wheel is "ghetto" only fit for ghetto ITRs. You don't want that.
Old Jun 3, 2002 | 05:44 PM
tatty's Avatar
New User
Yes I've seen it done...you people need to visit the Philips lighting forum.
Any kind of modification/retrofitting/blah blah has been done by one person or another on this forum:
http://www.lighting.philips.com/foru...6/wwwforum.cgi
awong3321
Acura TL, RL & ZDX
Nov 8, 2009 10:02 PM
lil kid
Honda Civic (2001 - 2005)
11
Aug 21, 2008 02:26 AM
just_dung
Northwest (Sales)
May 7, 2008 10:08 PM
- Sim -
Sep 24, 2004 05:16 PM
FusionITR
Dec 5, 2001 11:57 PM
