Anyone running B.Crower VTEC cams?
Old Mar 26, 2007 | 06:29 PM
t . b o z's Avatar
Default Anyone running B.Crower VTEC cams?
I can't decide between the Stage2 N/A or Stage3 for a GSR. You can't beat his prices, and quality looks top notch.
Anybody running these have a dyno sheet? What kind of numbers could I expect?
Old Mar 26, 2007 | 07:24 PM
R.Kelley's Avatar
Default Re: Anyone running B.Crower VTEC cams? (t . b o z)
ive got the stage 2 cams, they look nice in the box. I'm just waiting on my bottom end to come back from the machine shop
Old Mar 26, 2007 | 09:35 PM
t . b o z's Avatar
Default Re: Anyone running B.Crower VTEC cams? (R.Kelley)
cool..
Anyone else?
Old Mar 26, 2007 | 09:40 PM
Natural Aspirations's Avatar
Stock GSR engine? If so why even consider stage 3?
Old Mar 26, 2007 | 10:00 PM
t . b o z's Avatar
Default Re: (Natural Aspirations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations &raquo;</TD></TR><TR><TD CLASS="quote">Stock GSR engine? If so why even consider stage 3?</TD></TR></TABLE>
Ill be bumping it up to 11.8:1
Old Mar 27, 2007 | 04:03 AM
R.Kelley's Avatar
yea mine will be right around 12.3:1
Old Mar 27, 2007 | 04:04 AM
salman's Avatar
very hard to tell,
it all depends upon u
Old Mar 27, 2007 | 05:06 AM
Default Re: (t . b o z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t . b o z &raquo;</TD></TR><TR><TD CLASS="quote">
Ill be bumping it up to 11.8:1</TD></TR></TABLE>
Stage 2 will be your best bet, look at the engines they used for the dyno's on their site.
Old Mar 27, 2007 | 02:40 PM
t . b o z's Avatar
Actually, I've found a source for a b20 shortblock..
Im planning on :
84.5mm b20 shortblock (stock sleeves)
RS machine ITR race spec 84.5 pistons
Eagle Rods
OEM Honda Bearings
GSR Head
B.Crower valvetrain
B.Crower Stage2 cams
AEBS manifold
Rage big tube tri-y
310cc injectors
ChromePro w/ Moates Ostrich
Hopefully, that'll yield 200+whp with a good broad torque curve. This is going to be my daily driver, with A/C and P/S.
Old Mar 27, 2007 | 07:44 PM
chris2000's Avatar
Does anyone actually know or questioned where these Brian Crower cams comes from?
I just wonder due to its low pricing.
Old Mar 27, 2007 | 09:26 PM
t . b o z's Avatar
Default Re: Anyone running B.Crower VTEC cams? (chris2000)
The cores come from either China or Taiwan...I can't remember.
Final machining, and polishing is done here.
Old Mar 29, 2007 | 07:47 AM
Rollo Lawson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t . b o z &raquo;</TD></TR><TR><TD CLASS="quote">The cores come from either China or Taiwan...I can't remember.
Final machining, and polishing is done here.</TD></TR></TABLE>
with that being said, pretty much every cam we see advertised for out motors are made in Taiwan.
chris2k-why question the cores? to be skeptical? why question B.Crower cores and not all of the other cams that are developed overseas? almost every cam is priced competively, as of late. so, he's just supplying us what we need...... affordable **** that works. i have the 0012's and i'm on the fence as to which cam i should use..the 0012's or Jun3's. my 0012's actually measured slightly larger than its advertised specs. both in & ex measured roughly 12.1mm. to the Op, don't even waste your time on the 0013's. they leave very little room for p to h/p to v clearance.
Old Mar 29, 2007 | 02:36 PM
t . b o z's Avatar
Default Re: Anyone running B.Crower VTEC cams? (Rollo Lawson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rollo Lawson &raquo;</TD></TR><TR><TD CLASS="quote">with that being said, pretty much every cam we see advertised for out motors are made in Taiwan.
chris2k-why question the cores? to be skeptical? why question B.Crower cores and not all of the other cams that are developed overseas? almost every cam is priced competively, as of late. so, he's just supplying us what we need...... affordable **** that works. i have the 0012's and i'm on the fence as to which cam i should use..the 0012's or Jun3's. my 0012's actually measured slightly larger than its advertised specs. both in & ex measured roughly 12.1mm. to the Op, don't even waste your time on the 0013's. they leave very little room for p to h/p to v clearance.</TD></TR></TABLE>
Most cores are produced overseas, even the big American companies farm cores from somewhere outside the country. However, some cam manufacturers have something called a "premium core" which is produced in the states, then grinded in the states. IMO, as long as its GRINDED by someone reputable, Im fine with it. Thanks for the info about the 0013's, I definitely won't be using those.
Old Apr 8, 2007 | 09:01 PM
CivicB18C1's Avatar
email brian urself like i did. im running ls block bored +20. wiseco 12.1:1 pistons eagle rods and crower .5mm oversized valves, ls valve reliefs, skunk2 retainers and springs and he guarentees the stage 3's will work fine with no clearance issues whats so ever. and i ahve it in writing.
Old Apr 9, 2007 | 07:38 AM
BlackLudeSi's Avatar
Default Re: Anyone running B.Crower VTEC cams? (CivicB18C1)
I have the stage 2's going in my 11.5-1 B16 with his full valvetrain. Should be ready to go in a few weeks just getting put together at the shop. On a side note my builder was impressed with the spring and cam combo says it should work great. Hoping to break 170whp with 1599cc's.
Old Apr 9, 2007 | 11:49 AM
onefstek's Avatar
im going to test the BC stage 3 cams vs the Jun 3 cams on my wife's car in the next week or so.
ill let you guys know the outcome.
818wHtEG6
Nov 7, 2007 02:53 PM
RippSpeed
16
May 18, 2007 08:56 AM
kshoua
May 22, 2006 11:49 PM
JMod
May 22, 2005 04:18 PM
Five-0-Five
Jul 14, 2004 08:04 AM
