99 ek ls vtech motor swap
Old Mar 26, 2007 | 05:10 PM
blade0314's Avatar
Default 99 ek ls vtech motor swap
hey i got a 99 civic ex and my friend wants to sell me a ls- VTECH motor and i was just wondering if that would fit in my car now this ls-vtech came from my friends 95 civic dx and if this didnt directly fit what modifications would i need to do ?
Modified by blade0314 at 6:51 AM 3/27/2007
Old Mar 26, 2007 | 05:58 PM
blk_EK's Avatar
Default Re: 99 ek ls vtech motor swap (blade0314)
SEARCH!!!
Look in the Honda-Tech arcives. It tells you everything about swaps for Civics!
Old Mar 26, 2007 | 05:59 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blade0314 &raquo;</TD></TR><TR><TD CLASS="quote">hey i got a 99 civic ex and my friend wants to sell me a ls- vtech motor and i was just wondering if that would fit in my car now this ls-vtech came from my friends 95 civic dx and if this didnt directly fit what modifications would i need to do ?</TD></TR></TABLE>
First off, it's VTEC, not vtech.
If it's in a DX than it already has the B series mounts, the motor itself will drop in 100%. You'll need OBD-IIB dizzy or rip the guts out of the LS/VTEC dizzy and put 'em in a OBD-IIB casing (or simply re-wire an OBD-II plug onto it). You'll need an OBD-IIB to OBD-I ECU conversion harness so the ECU will plug in. I also think you'll need OBD-II injectors so it'll plug into your harness.
The dizzy plug is rewireable, easy, 6 wires, the OBD-IIb to OBD-I harness is like 70 last time I saw one, and the injectors are cheap if they're the stock 240's.
The B series axles and mounts will work in ur car, as for the shift linkage, I'm not sure.
It's a pretty straight forward swap.
Search next time, this has been covered countless times.
Old Mar 26, 2007 | 06:03 PM
MilanoCivic97's Avatar
Default Re: 99 ek ls vtech motor swap (Syndacate)
i'd learn how to spell VTEC before attempting to build an LS VTEC
Nfrigo
Sep 24, 2017 06:23 PM
blade0313
May 9, 2007 06:17 PM
blade0314
Mar 27, 2007 06:13 AM
highcomp
Mar 16, 2004 08:09 PM
