Sizes of the brake bleeder screw?
Raceshopper tells me that for the 98 integra gsr:
Front - 10mmx1.25
Rear - 8mmx1.25
Is this correct? I always thought the rear was the same as the front.
-and they mentioned that speed bleeder's website is not correct.
--hrmm, second thought, whenever I've bled in the past, I've only used my 10mm flare nut wrench...
FIGURED IT OUT
Got around to trying it, and raceshopper was wrong! At least they'll be sending me 10mm's for the rear.
Modified by erikiksaz1 at 6:53 PM 3/28/2007
Front - 10mmx1.25
Rear - 8mmx1.25
FIGURED IT OUT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet »</TD></TR><TR><TD CLASS="quote">it is the same size 10mm. speedbleeder screw are smaller for some odd reason. which is 8mm. </TD></TR></TABLE>
Hrmm, I don't follow, so will it work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erikiksaz1 »</TD></TR><TR><TD CLASS="quote">
all stock bleeder screws on hondas/acuras are 10mm. the aftermarket quick bleeder screws like Russel are 8mm for some odd reason. I figured it's because it's actually a standard size and not metric.
</TD></TR></TABLE>all stock bleeder screws on hondas/acuras are 10mm. the aftermarket quick bleeder screws like Russel are 8mm for some odd reason. I figured it's because it's actually a standard size and not metric.
How do they manage to fit?
****, the guy from raceshopper told me they should work, and that they'd honor the return even if the package has been opened. I just don't feel like having to bleed the brakes twice after having introduced air into the system needlessly.
