can you use any h series oil pan gaskets on an h22a4
im not sure if you use an oil pan gasket on the h22a4. but i have a pretty bad leak im trying to find and i would like to rule out the oil pan. im just wondering if the bolt pattern is the same for all h series.
If you use the a4 oil pan make sure and buy the little gasket that goes by the rear main seal.
As said above, it uses honda-bond.
