Vtec Controller into GSR'd EF..
Old Mar 26, 2007 | 09:20 AM
ProjectLSVTEG's Avatar
Default Vtec Controller into GSR'd EF..
I am assuming this will work without a problem, however I am swapping a OBDI GSR engine into my Dual Point EF sedan, and am converting the Dual Point Harness to Multi-Point. I will be using an OBD0-OBDI jumper harness to run the GSR ECU. I am assuming and am like 99% sure that wiring a Vtec controller into it in the typical OBDI manner is going to work, just wanted reassurance.
Old Mar 26, 2007 | 10:18 AM
Slurp56's Avatar
Default Re: Vtec Controller into GSR'd EF.. (ProjectLSVTEG)
You dont need the VTEC controller if you are running an OBD1 GSR ECU. However, if you want to run the VTEC controller, then it is just the same as wiring into an OBD1 vehicle
Old Mar 26, 2007 | 10:20 AM
Default Re: Vtec Controller into GSR'd EF.. (Slurp56)
I know I don't need the VTEC controller while running the ECU, but may want to run a Vtec controller down the road.
Old Mar 26, 2007 | 01:52 PM
b18CrxSi91's Avatar
71.179.86.205
I think someone makes a OBD0-OBD1 jumper with a vtec controller harness with it so all you have to do is plug it in.
Im geussing rywire? someone correct me if im wrong.
Old Mar 26, 2007 | 03:40 PM
Deetz's Avatar
Crazy Honda Guy
Why bother if running obd1. Just run a uberdata program which can be downloaded for free. It will do everything a vtec controller can do, plus a hell of a lot more. Your only cost, $15 for the kit to chip your ecu.
Old Mar 26, 2007 | 04:11 PM
Bejita's Avatar
Vtec controllers are ******* retarded......
When you expletive with that stuff without actually doing a fuel map and timming tune then you're actually hurting your performance rather than helping it. It's like those idiots who use the MSD Vtec activator piece of **** instead of doing it right and getting the right ECU and doing the proper wiring
Old Mar 26, 2007 | 05:55 PM
EF2_Sedan88's Avatar
Default Re: Vtec Controller into GSR'd EF.. (b18CrxSi91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18CrxSi91 &raquo;</TD></TR><TR><TD CLASS="quote">I think someone makes a OBD0-OBD1 jumper with a vtec controller harness with it so all you have to do is plug it in.
Im geussing rywire? someone correct me if im wrong.</TD></TR></TABLE>
rywire does but u need to send then ur vtec controller harness and and they will do it but this place will do it http://www.boomslang.us/obd0to1.htm without having to send then nothing thats wut I have
Old Mar 26, 2007 | 06:52 PM
Crx Jimmy's Avatar
Default Re: Vtec Controller into GSR'd EF.. (EF288Gsr)
Well he might not even want to use the vtec controller part they DO have other features. I have a data systems one and it has a adjustable rev warning, a dual/split time timing system to time laps. and it has a nifty digital tach built in. I dont use the vtec feature I just like the other nifty stuff it has, and it was used and cheap and came with a obd0 to obdo harness so no splicing
Im not sure if this is true but this was posted on another page about it
"The Data Systems Concealed VTEC Controller is a new entry into the VTEC controller market. This VTEC controller has become very popular in Japan over the last few years. The controller allows you to adjust the VTEC crossover point and at the same time, automatically adjust the fuel and timing to optimize performance."
sway892
Aug 21, 2008 08:42 PM
1net
Mar 5, 2008 04:12 AM
[626] SiRJKwIcK89Ef
27
Oct 10, 2001 03:33 PM
