ist gen b16a o2 sensors
Old Mar 26, 2007 | 07:59 AM
b16a3delsol's Avatar
Default ist gen b16a o2 sensors
Im putting a 1st gen b16a into my del sol and was wondering if the the 1st gen b16a had primary and a secondary o2 sensors or if one is something else. Thank you
Old Mar 26, 2007 | 08:16 AM
Default Re: ist gen b16a o2 sensors (man with one cam)
The engine is obd-o can i just disregard one of them or will it need to be wired up.
Old Mar 26, 2007 | 08:19 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: ist gen b16a o2 sensors (lsdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsdelsol &raquo;</TD></TR><TR><TD CLASS="quote">The engine is obd-o can i just disregard one of them or will it need to be wired up.</TD></TR></TABLE>
If your keeping your car & ECU OBD-1, then you will only need the primary O2 sensor (the one before the cat). If your converting the car to OBD-0, then you will need to wire it up however the OBD-0 ECU works...
Old Mar 26, 2007 | 08:23 AM
Im staying obd-1 but if im not mistaken they are both before the cat. Thats why i was wondering if one was a primary and one was a secondary.
Old Mar 26, 2007 | 09:15 AM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by man with one cam &raquo;</TD></TR><TR><TD CLASS="quote">obd1 has one and 0bd2 has two</TD></TR></TABLE>
He is saying his motor is OBD-0 and it has two O2 sensors before the cat. He wants to know which one he should keep. I would probably keep the front one, or whichever one had 5 wires on it. If both have 5 wires (or the same number of wires), then I would just keep the one that was in or just past the collector of the header...
Old Mar 26, 2007 | 11:08 AM
schardbody's Avatar
damn, nothing hard about this one.
obd0 ecu being used (doubt it but hey) single 1 wire o2
obd1 ecu being used (most likely) single 4 wire heated o2
obd2 ecu being used (less likely, but possible) 2 4 wire heated o2s, one upstream, one downstream, upstream being closest to the cylinder head and being the primary. both will be needed to keep a code from being stored and the CEL from illuminating.
Old Mar 26, 2007 | 07:42 PM
Default Re: (man with one cam)
Thanks that helped. Sorry i just couldnt put it into the right words.
Go n 4 10s
Mar 27, 2006 09:38 AM
Go n 4 10s
Mar 17, 2006 01:44 PM
joedr
Jun 7, 2002 04:58 AM
handiman15
Mar 6, 2002 07:32 PM
