Yet another injector cleaning question (different method)
Old Mar 26, 2007 | 07:15 AM
clayne's Avatar
Default Yet another injector cleaning question (different method)
So I'm aware of the AA battery method, seafoam, fuel cleaner, etc. methods. Unforunately I've got a set of injectors that are just plain fouled with either particulates, bad gas, or deposits from bad gas. Fortunately, I've got a set of working injectors on the car now. The AA battery method is a huge hack, and it's not necessarily good for injectors as it isn't getting a PWM voltage, but a constant one (bad, and I've already tried it and it didn't work very well), so I've been wondering about a different method.
Would the following work without any issues:
1. Leave working injectors in, everything normal.
2. Pull ignition wire from cylinder #4 on the distributor end.
3. Unclip injector harness from inector #4.
4. Start car, let it idle on 3 cylinders, with #4 good injector doing nothing but sitting there in the fuel rail.
5. Use injector harness #4 manually connected to a bad injector and spray carb cleaner through it collected into a separate container effectively using real PWM output from the car to open/close the bad injector and carb cleaner to clean any serious fouling.
6. Follow with some WD-40 to wash any internal traces of carb cleaner away.
7. Repeat for each bad injector.
Anyone see any issues with this? I'm trying to think of potential safety ones, but besides using carb cleaner in the engine bay while the car is running (people do it all the time for various reasons) I can't really see it being that unsafe as long as it's being collected into something. Idling on 3 cylinders shouldn't hurt anything either.
Old Mar 26, 2007 | 07:19 AM
mmuller's Avatar
Mad Scientist
Default Re: Yet another injector cleaning question (clayne)
the thing is that old dried up varnished gas is a real beatch to clean.
i clean lots of bike carbs and let me tell you that a lot of times nothing short of putting it in the ultrasonic cleaned works..
Old Mar 26, 2007 | 07:44 AM
clayne's Avatar
Default Re: Yet another injector cleaning question (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">the thing is that old dried up varnished gas is a real beatch to clean.
i clean lots of bike carbs and let me tell you that a lot of times nothing short of putting it in the ultrasonic cleaned works..</TD></TR></TABLE>
Yep. Although I don't think these injectors are totally trashed, as they *were* working before my last build - but since it took a while, I'm suspecting particulate matter while I had them out, or otherwise bad gas still present on restart. If it doesn't work, I'll just have them professionally dealt with.
Old Mar 26, 2007 | 08:15 AM
mmuller's Avatar
Mad Scientist
go by the yamaha dealership and buy their carb clean solution. works amazing.
Old Mar 28, 2007 | 02:49 AM
SJersey's Avatar
Whats wrong with sending them in for service?
http://kgparts.com/index.php?page=fuelinjectclean
Sounds as if professional cleaning is in order...
boostedteg4dr
Nov 30, 2013 01:17 PM
a1320honda
Sep 23, 2007 01:06 PM
m1nh
Jul 4, 2005 10:50 PM
kndaqikEG
May 2, 2005 07:38 AM
Zooper
Aug 23, 2004 09:15 AM
