Question on Hasport Driver-side Mount Doesn't Fit on JDM ITR(B18C) Motor in an CRX
Old Mar 26, 2007 | 04:44 AM
CW-ITR's Avatar
Default Question on Hasport Driver-side Mount Doesn't Fit on JDM ITR(B18C) Motor in an CRX
For some reason the driver-side Hasport mounting holes are too wide for the two studs. Any idea why?
Can someone please post a close-up picture of the Hasport driver side mount mounted on a JDM ITR engine? Thanks.
Old Mar 26, 2007 | 05:43 AM
CRX Toad's Avatar
Default Re: Question on Hasport Driver-side Mount Doesn't Fit on JDM ITR(B18C) Motor in an CRX (CW-ITR)
I'd give HaSport a call. That is some of what you pay for customer support.
Old Mar 26, 2007 | 06:09 AM
EpicTuning's Avatar
You need a 90-93 Integra engine bracket. You can't use the one that came with the Type R engine.
Old Mar 26, 2007 | 09:44 AM
QuarterMileMaster's Avatar
Default Re: Question on Hasport Driver-side Mount Doesn't Fit on JDM ITR(B18C) Motor in an CRX (EpicTuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EpicTuning &raquo;</TD></TR><TR><TD CLASS="quote">You need a 90-93 Integra engine bracket. You can't use the one that came with the Type R engine.</TD></TR></TABLE>
100% right. I ran into this as well. Get the motor mount bracket of an old 90-93 ls at the junk yard and mount it to the ITR block, and use the hasport mount. Then it will fit.
Old Mar 26, 2007 | 10:11 AM
IT GUY's Avatar
Default Re: Question on Hasport Driver-side Mount Doesn't Fit on JDM ITR(B18C) Motor in an CRX (QuarterMileM
The rear L bracket needs to be from a DA integra as well...
Old Mar 26, 2007 | 11:08 AM
CW-ITR's Avatar
Thanks guys for the info. It's kind of dump that Hasport can't produce mounts that would bolt right up to the B-series brackets without going out and source for D-series mounts &lt;---Now, where is the "hit it in the head" icon?
Old Mar 26, 2007 | 11:12 AM
Wes V's Avatar
The Integra motor bracket (mount) is NOT a D series part!
You can't expect Hasport to have a mount for every configuration. What they did is make it for the most readily available parts.
Wes
Old Mar 26, 2007 | 01:48 PM
b18CrxSi91's Avatar
71.179.86.205
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW-ITR &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys for the info. It's kind of dump that Hasport can't produce mounts that would bolt right up to the B-series brackets without going out and source for D-series mounts &lt;---Now, where is the "hit it in the head" icon?</TD></TR></TABLE>
Someone was saving it just for you lol.
Old Mar 26, 2007 | 03:58 PM
CW-ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">The Integra motor bracket (mount) is NOT a D series part!
Wes</TD></TR></TABLE>Thanks Wes for your input. But, let's take it from a customer point of view(like mine). The B-series swap into CRX is the most popular swap there is, not the D-series. So, why not make the mounts to fit the B-series brackets. Why do they have to fit D-series brackets? If I missed some thing, I'm all ears.
Old Mar 26, 2007 | 03:59 PM
CW-ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18CrxSi91 &raquo;</TD></TR><TR><TD CLASS="quote">
Someone was saving it just for you lol. </TD></TR></TABLE>If my statement above makes sense, some one is saving that hamer for you
Old Mar 26, 2007 | 04:44 PM
Wes V's Avatar
CW-ITR;
<U>The motor mount bracket that you need is from a USDM Integra B motor, not D!!</U>
It's better for the average consumer that the part required comes from a USDM car that is easy to locate in junk yards.
If Hasport made the mount to fit your JDM motor bracket, then it wouldn't work for my USDM GSR installation without me having to source a JDM part. More difficult than finding a USDM part.
Wes
Old Mar 26, 2007 | 04:49 PM
88 rex's Avatar
&lt;---Agrees with Wes but can understand the frustration in all the little "extras" involved in a swap that most peolple don't talk about.
Old Mar 26, 2007 | 05:30 PM
Steri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW-ITR &raquo;</TD></TR><TR><TD CLASS="quote"> If I missed some thing, I'm all ears.</TD></TR></TABLE>
you missed what Wes said, it's in the passage that you quoted. It does fit a B-SERIES mount, just not your JDM B mount. It fits the USDM B mount which is more readily available and probably cheaper to get.
Old Mar 27, 2007 | 11:34 AM
CW-ITR's Avatar
Now, I understand. Someone quick, hand me that hammer please or just drop it on my head Thanks for the education guys. Greatly appreciate all your inputs Now, I'm going to get all those parts and finnish up my swap.
the soL that could
Welding / Fabrication
Aug 21, 2011 09:12 PM
kelsodeez
Jan 9, 2010 09:33 PM
s2k_al
Jan 27, 2005 12:02 AM
vitrox
Jun 11, 2004 05:31 PM
Scorch7
Dec 27, 2002 02:30 PM
