Instrument cluster fuse keeps popping?!?! help...
Old Mar 26, 2007 | 01:14 AM
TA Performance's Avatar
Default Instrument cluster fuse keeps popping?!?! help...
Hey guys while i was driving few nights ago all of a sudden my cluster, interior, front sidemarkers, corner signals, and taillights stop working. The problem is the fuse for the instrument cluster/tailights popped and i tried to replace it with 10,15,20,25,30 amp fuses and it keeps popping as soon as i turn over the light switch on my steering column. I spent hours tryingn to figure it out, i took off my whole front end to check for wires shorting out, took out my whole climate control and ripped out my indash tv to see if thats the problem, and even ripped apart my dash to check if my alarm has loose wires or wires grounding/shorting out. I found nothing wrong i even rewrapped all wires with electrical tape. This problem is really bugging me and id really appreciate fellow hondatech members help since you guys are hella useful and given good information/help many times before!!!
Help a brotha out!!!!
thanks
Old Mar 26, 2007 | 05:50 AM
fcm's Avatar
fcm
Old Fart
Default Re: Instrument cluster fuse keeps popping?!?! help... (TurboSpirit_DC2)
First, never replace a fuse with a bigger one, you can literally burn your car to the ground.
What is the MM&Y of the car?
You have checked the most common cause of that fuse blowing, but check again, pull the HU, [in-dash TV] check the red/black lead, [illumination] in the stock radio harness, make sure it is not shorting to ground.
Also, when does the fuse blow, as soon as you put it in, or as soon as you turn on the park lights? 94
Old Mar 26, 2007 | 05:54 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> and it keeps popping as soon as i turn over the light switch on my steering column. </TD></TR></TABLE>
I would also suspect the illumination wire is either incorrectly connected or shorting to ground.
As FCM stated, check it again.
Old Mar 26, 2007 | 07:17 PM
Default Re: Instrument cluster fuse keeps popping?!?! help... (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> First, never replace a fuse with a bigger one, you can literally burn your car to the ground.
Also, when does the fuse blow, as soon as you put it in, or as soon as you turn on the park lights? 94</TD></TR></TABLE>
damn a litttle to late i melted my rear taillight harness!@!!!
for your help
Old Mar 27, 2007 | 06:23 AM
fcm's Avatar
fcm
Old Fart
Oops! 94
SIR EF9
Dec 20, 2008 01:05 AM
TA Performance
Mar 26, 2007 06:25 AM
unknown0001
Aug 9, 2006 02:03 PM
93WhiteHatch
Apr 29, 2006 05:58 PM
petersayarath
Oct 11, 2005 12:09 PM
