Points of failure on a D15B7
Old Mar 25, 2007 | 08:29 PM
ZMX's Avatar
ZMX
Default Points of failure on a D15B7
I was wondering what would have to be done to a D15B7 for it to take more power. I know that by default the max is around 50 extra HP (100 -> 150). I assume that getting better connecting rods would be first, but what would be after that?
Old Mar 25, 2007 | 09:24 PM
GG99's Avatar
Default Re: Points of failure on a D15B7 (ZMX)
only way to make any real power on a d series is to boost it/
Old Mar 26, 2007 | 02:37 AM
ZMX's Avatar
ZMX
Default Re: Points of failure on a D15B7 (GG99)
That's not what I'm asking. Boost or NOS would work to give it more power, yes, but what parts would I change to make the engine be able to run at 250 HP without blowing up?
Old Mar 26, 2007 | 05:29 AM
ZMX's Avatar
ZMX
To rephrase again, I'm not asking how to give it more power, but how to make it withstand more power.
Old Mar 26, 2007 | 06:38 AM
Libertariat's Avatar
Ek Forever y0!
D series on stock internals can hold just overt 200 whp on a good tune.
To withstand more, you'll need cams, valves/retainers, pistons and rods.
It's pretty much common sense, if you want your engine to be stronger, use stronger parts.
EDIT: Oh, and a kickass clutch,
Old Mar 26, 2007 | 07:02 AM
RedDC5's Avatar
Default Re: Points of failure on a D15B7 (ek forever guy)
Search. Though the initial car is a vtec build, there are several nonvtec built singles mentioned in the same thread. It took me like 5 minutes to find this with that little red button on the top right part of your screen.
https://honda-tech.com/zerothread?id=1572806
Old Mar 26, 2007 | 12:52 PM
ZMX's Avatar
ZMX
Default Re: Points of failure on a D15B7 (FerioEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FerioEG &raquo;</TD></TR><TR><TD CLASS="quote">Search. Though the initial car is a vtec build, there are several nonvtec built singles mentioned in the same thread. It took me like 5 minutes to find this with that little red button on the top right part of your screen.
https://honda-tech.com/zerothread?id=1572806</TD></TR></TABLE>
Congratulations, jackass, you can tell me to search. Even better, to prove your worth, you can give me a link that doesn't come close to answering what I asked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "ek forever guy" &raquo;</TD></TR><TR><TD CLASS="quote">D series on stock internals can hold just overt 200 whp on a good tune.
EDIT: Oh, and a kickass clutch, </TD></TR></TABLE>
What about the crankshaft and bottom end? I can't find anything on how much power they can take.
95musubi
Feb 25, 2010 08:51 AM
cons
Jun 13, 2005 01:19 PM
DIRTY FACE
Feb 19, 2004 07:05 AM
CimorelliCRX
Apr 2, 2003 07:46 PM
