Low Idle, unplugged EGR valve connector and nothing happerned?
Old Mar 25, 2007 | 03:39 PM
JBirch_97Prelude's Avatar
Default Low Idle, unplugged EGR valve connector and nothing happerned?
Does this mean, the EGR is the problem? I found leaks in the EGR vacumm hose and replaced it. The car would not idle still so I unplugged the EGR connector and nothing happened. Could the culprit be the EGR Valve?
Old Mar 25, 2007 | 08:19 PM
93sivtec's Avatar
The egr only opens by vaccum under load at higher rpms I belive,so it wouldnt really matter at idle.But u can remove it and clean it with carb cleaner.
Old Mar 26, 2007 | 08:43 AM
Default Re: (93sivtec)
Thanks alot!
Praetor353
Apr 28, 2009 03:59 PM
thunderboy
Jan 27, 2008 10:24 AM
jdmboy
Sep 6, 2005 03:30 PM
caliquick_teg
Jan 23, 2003 05:34 AM
