Apex'i turbo installed... Blow off valve questions/ availability
Old May 24, 2002 | 03:56 PM
ITR1071's Avatar
Default Apex'i turbo installed... Blow off valve questions/ availability
I have an Apexi turbo for may 95 civic ex and want to know 1 if all weld application blow off valves MUST be welded or can they be bolted.
2 - I would like to know what all bolt on BOV are available for it.
Thanks
By the way, I am SPOOL, using UndercoverSI's id screen name.
[Modified by undercoverSI, 12:57 AM 5/25/2002]
[Modified by undercoverSI, 12:58 AM 5/25/2002]
Old May 25, 2002 | 02:45 AM
SpeedRacerEX-R's Avatar
Default Re: Apex'i turbo installed... Blow off valve questions/ availability (undercoverSI)
Any bov that you want to run will work. And they all require that you weld a flange on.
Old May 25, 2002 | 09:02 AM
senpai's Avatar
My BLITZ DD BOV bolts right on.
Old May 25, 2002 | 10:08 AM
HENRY's Avatar
New User
Doesn't the Apex kits come with a flange for the BOV already welded on? If so, then I would probably stick with an Apex BOV just to make your life easier. Unfortunately, I don't know what other brand of BOV's fit.
cbustuner
Apr 22, 2009 05:13 AM
Fab-Works
Welding / Fabrication
Aug 23, 2005 05:02 AM
M.A.R.C.
Aug 2, 2002 07:51 AM
