Suspension & Brakes Theory, alignment, spring rates....
installation question EG hatch. Please Help!!
Old Mar 25, 2007 | 01:27 PM
bigfigman's Avatar
Default installation question EG hatch. Please Help!!
So i bought a set of Tokico HP blues and RSR lowering springs for my 92 VX hatch. After installing the front shocks and springs everything seemed to be ok, until i test drove the car. I heard a rattling noise from under the hood, so i turned back and parked in the garage. I opened the hood to find that the shock piston(the stainless steel part) pushed thru the pillow mounts and hit my hood. Happened on both sides. The Tokicos are the same length as the OEM shocks but the RSR springs are shorter than the stock ones. Is this my problem or did i forget a piece? Any info wil be greatly appreciated. thanks in advance.
Old Mar 25, 2007 | 02:59 PM
BlueIntegraBoy's Avatar
Default Re: installation question EG hatch. Please Help!! (bigfigman)
You forgot the bump stop #14
Old Mar 25, 2007 | 03:18 PM
ThoseDarnKids's Avatar
Default Re: installation question EG hatch. Please Help!! (BlueIntegraBoy)
Sure did!
Make sure it is the proper washer too... that big, beefy one. I've taken apart a guy's shock only to find that he has used a washer, like #6, in place of #14. It was all bent inwards and about to send the shock through the hood. It's very important that #14 is installed!
Old Mar 25, 2007 | 04:19 PM
bigfigman's Avatar
Default Re: installation question EG hatch. Please Help!! (ThoseDarnKids)
i knew it, thanks a lot guys. appreciate the time.
averyvm
Jul 13, 2009 09:39 AM
al3e
46
Aug 13, 2007 12:29 AM
2kcord
Nov 4, 2006 03:03 PM
NikoZai
24
Mar 23, 2005 02:49 AM
