B18C Build Questions
hey guys, i am building up a b18c1 to drop in my integra and i was wondering what kinda whp numbers i could expect.
my plan is to use aftermarket forged rods and probably JDM ITR Pistons for the block.
also going to run a full valvetrain matched to the cams i will use on a mildly P&P b18c head
my question is should i look into forged pistons or will oem/aftermarket cast pistons be good enough
and also i want the engine to run smooth, i was thinking about wither skunk2 pro1's or blox a's or b's. any recommendations for cost effective cams that will put out some decent numbers?
Modified by nate_2k5 at 2:13 PM 3/25/2007
It just all depends on how much you want to spend. I at this point am sticking with stock balanced internals and Pro2 cams. Pro 1s are a good all around choice though.
it shouldn't really be a question of how much to spend as far as power output as far as compression and the head goes.
other things i would add are a high flow fuel rail, adjustable FPR, SS header to 2.5" exhaust, probably a whale ***** intake, and i was hoping that the BBK SSI intake mani would fit into this setup well or this that more of a FI manifold?
i guess my main thing is will i be able to break 200whp and 150wtq with a setup similar to that?
Well now that you have youre intake and exhaust setup pretty much decided. Oh and another thing, if youre running forged rods, you might as well run forged pistons as well, with the wrist pin situation and all. with the engine running smooth, its all in the tune of course.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">Smooth would be cast pistons and "R" cams. Actually just buy a new type "R" and run that , cannot get much smoother. (Maybe a LS)</TD></TR></TABLE>
i want a motor that will be a little more powerful than a stock R so i can sacrifice some comfort for that but i want a somewhat smooth idle and throughout the rev range.
are they unneeded? i actually sold off my forged so i am plannin on going stock now...are type R stronger than gsr? should i have them shot peened?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg »</TD></TR><TR><TD CLASS="quote">
Go w/ the blox type b cams. Why run forged rods though?</TD></TR></TABLE>
also can i get 200whp out of these cams?
kart_driver
26
Aug 31, 2010 01:07 PM
eg6madness
19
Nov 25, 2006 01:44 PM
A2_8U
10
May 31, 2006 11:15 PM
