b16a2 using thicker head gasket to reduce compression ratio for a turbo vs new pistons
Old Mar 25, 2007 | 09:47 AM
crackdaddy's Avatar
Default b16a2 using thicker head gasket to reduce compression ratio for a turbo vs new pistons
ok i have a b16a2
i am currently broke..but i am dreaming of eventually turboing my car
i was wondering whats the cheapest way to turbo up my car
-note, i want it to be cheap, but i dont want to waste my money
(ie i dont want to do mod "A" then when im ready for mod "B"
the mod "A" crap is useless)
also i dont want to spend money/time for getting more power if its not gonna be much gains
i am very new to car tuning
the 3 way i know of to get more power via turbo for this car are:
1)keep stock internals, add turbo
psi boost: ?
whp gains: ?
2)use thicker head gasket, add turbo
psi boost: ?
whp gains: ?
3)buy lower compression pistons only, add turbo
psi boost: ?
whp gains: ?
-also if mthod 3 is the best, how much better
would it be to go ahead and do the crackshaft, and cams etc...
i know the absolute best would be to build the engine all the way
but thats megga money
i questions is what the the correct path(order) of mods to do
, which ones Must be done together
,and which ones can wait
Old Mar 25, 2007 | 09:52 AM
cambopheonix56's Avatar
Default Re: b16a2 using thicker head gasket to reduce compression ratio for a turbo vs new pistons (crackdad
Dude, you have no idea what you are talking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crackdaddy &raquo;</TD></TR><TR><TD CLASS="quote">
psi boost: What Turbo
whp gains: Try to stay under 300whp
psi boost: This idea is dumb, refer to option 1
whp gains: 0
psi boost: See option 1
whp gains: 0
Turbo the stock motor, Just go the easy way and buy a peakboost kit. Has a t3/t04 turbo I think. Doesn't matter what psi, as long as you have it tuned good and you stay around 250-300 whp. You will be golden.
Old Mar 25, 2007 | 10:40 AM
mugeneghatchie's Avatar
8 psi would be good i wouldnt go over it if so youll need a new intakemainfold bigger injectors n a block gaurd with 8 psi you should be in the 250-275 hp range !
Old Mar 25, 2007 | 10:47 AM
Default Re: (mugeneghatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugeneghatchie &raquo;</TD></TR><TR><TD CLASS="quote">8 psi would be good i wouldnt go over it if so youll need a new intakemainfold bigger injectors n a block gaurd with 8 psi you should be in the 250-275 hp range !</TD></TR></TABLE>
How can you say that when you don't know what size turbo, cams, log or equilength manifold, ect..?
DC4R27
Oct 6, 2007 07:34 PM
Dasani
Jul 5, 2006 02:39 PM
Arch-Angel
Jul 11, 2003 12:56 AM
DualKnuttz
Mar 14, 2003 06:52 AM
joe pagolac
Aug 22, 2001 02:15 PM
