h22 injectors? identifying ?
i have a set of h22 injects i got off from a friend. Did some searching but keep getting mixed answers. I plan to throw these injectors into my obd1 95 gsr thats supercharged.
we put the injectors in before the car ran fine for a month or so then i searched again and found that h22 injectors are peak and hold and the gsr is saturated? or vice versa forgot , correct me if im wrong. So my question is What injectors do i have? their black tipped, and have 1GJE on one and the other three 1GJF . will these work on my car and what injectors are those?? thanks for ur help
91-95 h22 injectors are peak and hold. 96 and up are saturated. you will need saturated unless you wire in a resistor box. Get a multimeter and test the resistance between the two metal tabs in the injectors. IF it is like 2.5 omhs they are saturated. if it is closer to 14.7 ohms they are peak and hold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludestud11 »</TD></TR><TR><TD CLASS="quote"> Get a multimeter and test the resistance between the two metal tabs in the injectors. IF it is like 2.5 omhs they are saturated. </TD></TR></TABLE>
this info is incorrect. 1.5-2.5ohms are the specifications for obd1 peak and hold injectors
Mentat Ghola
Dec 22, 2004 11:24 AM
