Wiring Harness?
Old Mar 25, 2007 | 07:05 AM
Lost_clearance's Avatar
Default Wiring Harness?
Alright im struggling and confussed, ok for my wiring harness for my b16b, the jdm harness will not fit beucase its for right hand drive, but my EX harness some of the sensors are different, what should i do?
Old Mar 25, 2007 | 03:30 PM
civicstar's Avatar
Default Re: Wiring Harness? (Lost_clearance)
you only need the necessary wires, some are not needed, what ecu are you running? wat car is it in? eg or ek model?
Old Mar 26, 2007 | 03:17 PM
Default Re: Wiring Harness? (civicstar)
Its a 99 civic (ek) and i will be running the type R ecu
Old Mar 26, 2007 | 07:33 PM
civicstar's Avatar
can u identify which ones dont connect? the ones on the back of the block? wat yr is the engine?
Old Mar 27, 2007 | 02:12 PM
the engine is from a 99 type R, and the stock wiring harness is a 99 civic ex
Old Mar 28, 2007 | 07:53 AM
civicstar's Avatar
can you identify or take a picture of the ones that dont connect?
Old Mar 31, 2007 | 09:09 AM
alternator, distribuator are the main ones
Old Mar 31, 2007 | 09:52 AM
civicstar's Avatar
yeh, i forgot bout having to convert those over, on the 99 ex, it uses a diff distrib plug. your going to have to get a dist plug off an SI or any 96-98 civic, alternator, i forgot what plug or where to find, u can use ur single cam alternator, only thing is its not gonna line up with the top bolt, or u can try and find what clip it is
da59block
14
Nov 11, 2011 12:33 PM
Cprace1
Sep 12, 2005 09:50 AM
Se-rv-Tak
Feb 21, 2004 09:13 PM
EX-T
Oct 2, 2003 03:36 AM
