Strange idle, HELP!
Old May 24, 2002 | 02:21 PM
pittsburghCRX's Avatar
Default Strange idle, HELP!
Whenever I start my rex (91 dx) The engine idles @ 2000 rpm's and then slowly goes down to about 800... (takes a few min). It also sometimes loopes when idling. I just replaced the timing belt so thats not the problem. Any answers/suggestions as to what I might do? Thanks a lot.
Vince
Old May 24, 2002 | 05:29 PM
Lamchop0000's Avatar
Default Re: Strange idle, HELP! (pittsburghCRX)
when i do a cold start in the morning, it starts idling at 1400ish then goes down to 800ish when its fully warmed up. btw its a zc with 89 integ ecu. seems normal but im not too sure. late
[Modified by lamchop0000, 2:30 AM 5/25/2002]
Old May 24, 2002 | 09:27 PM
89 CRX SI's Avatar
Default Re: Strange idle, HELP! (lamchop0000)
iut is normal it does that when its cold. Try lertting your car run for a bit like 10 min then shut off start it up and itll idle at 800.
Old May 24, 2002 | 09:36 PM
88DXhatch's Avatar
check your AIC (air idle control)
maybe you have a small vacuum leak
Old May 24, 2002 | 11:53 PM
Gaijin's Avatar
Default Re: Strange idle, HELP! (88DXhatch)
Or maybe you have a clogged cat...
Old May 25, 2002 | 12:12 AM
MilanoRex's Avatar
Default Re: Strange idle, HELP! (Gaijin)
if your engine is cold, the ecu revs it to 2k so it can warm up faster.
purplerain11
12
Nov 24, 2011 08:00 PM
rickscrx
Feb 6, 2011 02:35 PM
teg racer 877
Sep 28, 2006 01:49 PM
kanzdj1
Feb 8, 2004 08:18 PM
RR98DX
May 9, 2002 04:46 PM
