Did you guys see this Dyno
Old May 24, 2002 | 02:07 PM
hooptie157's Avatar
Default Did you guys see this Dyno
port, polish and milling Ownzz
what about this one
[Modified by hooptie157, 3:11 PM 5/24/2002]
Old May 24, 2002 | 02:16 PM
spankaveli's Avatar
Default Re: Did you guys see this Dyno (hooptie157)
lesson 2: hondata ownz jo0
Old May 24, 2002 | 02:17 PM
B2FiNiTY's Avatar
We had a big debate on the spoon one...long story short, it is misleading.
Old May 24, 2002 | 02:19 PM
RTW DC2R's Avatar
Default Re: Did you guys see this Dyno (spankaveli)
could just be a ploy to make Spoon look like a terrible company. I know that I dynoed at 178 with just I/H(usdm)/no ps belt. So i seriously doubt that Spoon chart is legit. I guess anything is possible though.
Old May 24, 2002 | 02:31 PM
type r 01-1063's Avatar
maybe the motor in the spoon graph wasn't tuned or tuned properly.
it just looks like all the parts were just dropped in running stock ecu.
Old May 24, 2002 | 02:34 PM
hooptie157's Avatar
Default Re: Did you guys see this Dyno (type r 01-1063)
that what it looks like to me, but check out the first one 216 Hp hell yeah
sgT's Avatar
sgT
you are just reading numbers. you have no real basis to form a comparison
or to make any sort of assumption on what does what.
Old May 24, 2002 | 02:55 PM
done's Avatar
Default Re: Did you guys see this Dyno (sgT)
photochoped
Old May 24, 2002 | 02:57 PM
sgT's Avatar
sgT
Default Re: Did you guys see this Dyno (Jordo)
nah, i doubt it.
those numbers are indeed attainable, but people dont see the whole picture
Old May 24, 2002 | 02:59 PM
done's Avatar
im speaking of the words, those numbers are obtainable with the 1st ones mods?
Old May 24, 2002 | 03:10 PM
sgT's Avatar
sgT
If you know what you are doing
Old May 24, 2002 | 03:18 PM
Tony the Tiger's Avatar
I swear I would have achieved 240 WHP instead of my present 220 WHP if I had a stock ITR rad cap instead of a Spoon one...
Lesson learned about Spoon products
Old May 24, 2002 | 03:23 PM
sgT's Avatar
sgT
Default Re: Did you guys see this Dyno (Tony the Tiger)
gee, someone said just the other day you were making 250
Old May 24, 2002 | 03:47 PM
2.0L EK's Avatar
with stock cams and stock bottom end??? C'mon? Somthings wrong here. I aint buying it....
Old May 24, 2002 | 03:51 PM
sgT's Avatar
sgT
Default Re: Did you guys see this Dyno (2kTypeRHatch)
Like i said before, you people dont pay attention.
Old May 24, 2002 | 04:30 PM
Yeah, rumors suck eh?
But I swear I would have got 250 WHP if I took out that Spoon magnetic drain plug and that Spoon rad cap of mine... lol
Everything's achievable...
Old May 24, 2002 | 05:25 PM
Turbo Laser's Avatar
I actually think both of those charts are legit...
Old May 24, 2002 | 05:37 PM
InevitableRace's Avatar
sorry but i dont see 240 crank hp out of just a 1mm over piston and port and polished head and hondata.and it looks like to me that the stock cams didnt start dieing until 8500 they should have started to die around 8200 the blue line should have tarted to drop there.now let me ask you this why would you buy a skunk2 manafold when the R and the skunk have the same runners?Sorry i dont see it.The 240 hp should be the spoon motor looks more like it to me
Old May 24, 2002 | 05:43 PM
chirish's Avatar
Default Re: Did you guys see this Dyno (allmotrb18c1)
Look at the side of each dyno chart...One says "SAE corrected" and the other says "Actual"...If I'm not mistaken, SAE is a "corrected" horsepower rating, which would make the numbers seem low, or, corrected. I bet if the first dyno chart with the Hondata unit and what have you were to be SAE corrected, it would be as low, if not lower than the SPOON equiped ITR. You also have to take into consideration if the SPOON equipped ITR were on larger rims which would rob the car of a proper reading. And one more thing, you see how on the last dyno chart how there is a gap in the reading? That would indicate either a misfire or he let off and never got back on the throttle...don't always jump to a conclusion because of one graph...it might not be one of the better runs of the car.
Bottom line, I doubt a company like SPOON would manufacture parts that do not add any benefit or horsepower.
[Modified by PssshhhMr2, 2:48 AM 5/25/2002]
Old May 24, 2002 | 05:46 PM
acuracing's Avatar
Uhh, the top one is "Actual HP", while the second one is "SAE HP". Actual HP adds in the 10-15% frictional loss, while SAE is a truer "at-the-wheels" measurement.
Old May 24, 2002 | 05:47 PM
acuracing's Avatar
Default Re: Did you guys see this Dyno (PssshhhMr2)
Damn I leave my computer for five minutes and when I click "post", I see that you have beaten me to it. Gee Golly!
Old May 24, 2002 | 05:48 PM
chirish's Avatar
Default Re: Did you guys see this Dyno (acuracing)
Haha at least we are in the same boat Here, I'll delete my post and then re-post it after yours
Old May 24, 2002 | 05:49 PM
Ok so basicly he has 216hp to the crank didnt see that on the dyno sheet.thanks for letting me know
Old May 24, 2002 | 05:53 PM
acuracing's Avatar
You'll do that, for me? Thanks. hehe. Great minds think alike, eh?
Old May 24, 2002 | 07:27 PM
MaD3 In JaPaN's Avatar
probably switched them around!!!!!!!!!!!!!!!!!SPOON
