Suspension & Brakes Theory, alignment, spring rates....
OEM SI rear sway into EK sedan
Old Mar 24, 2007 | 08:14 PM
Hyjnx's Avatar
Default OEM SI rear sway into EK sedan
is this a direct swap? how would i know if i have the endlinks? what else would i need if i have everything on the car? like brackets and what not? thanks in advance
Old Mar 24, 2007 | 10:18 PM
Ukrainamese's Avatar
http://www.hondaautomotivepart...R+ARM
Si endlink part numbers are: 22778-Right 22779-Left
yes, it is a direct swap. sway bar, endlinks, brackets like you said bolt, nuts, etc.
Old Mar 27, 2007 | 07:08 AM
Jonas99's Avatar
Default Re: OEM SI rear sway into EK sedan (Hyjnx)
the only difference is that the si lower control arms are threaded, while the ex/dx just have through holes. just take that mounting bolt to sears and get a lock nut for the other end. everything lines up and bolts up fine.
Old Mar 29, 2007 | 08:36 PM
EeeJayEight's Avatar
Default Re: OEM SI rear sway into EK sedan (Jonas99)
are you sure they are threaded?
Old Mar 29, 2007 | 08:57 PM
ThoseDarnKids's Avatar
Default Re: OEM SI rear sway into EK sedan (EeeJayEight)
The Civic LCAs are not threaded. The factory endlinks still require nuts on the end of them.
The Integras have the threaded LCAs.
Old Mar 29, 2007 | 09:37 PM
Default Re: OEM SI rear sway into EK sedan (ThoseDarnKids)
exactly as i thought
hondaek
Texas -OK -LA (Sales)
Feb 8, 2012 12:09 PM
phan222001
Suspension & Brakes
Feb 20, 2010 02:42 PM
wazup_74
Jun 25, 2009 04:25 PM
Amuse9
Dec 30, 2002 12:48 PM
GokuSSJ4
10
Mar 17, 2002 11:11 PM
