96 del sol clutch housing
Old Mar 24, 2007 | 05:21 PM
delsoljunkie's Avatar
Default 96 del sol clutch housing
a piece of construction metal tore a hole in the clutch housing. any way to weld it closed or need total replacement? what does the replacement entail? full engine pull? already replaced the gas tank as it blew a hole in it just looking for what lies ahead.
Old Mar 24, 2007 | 08:13 PM
91DA9's Avatar
Default Re: 96 del sol clutch housing (delsoljunkie)
Are you talking about the sheet metal protector around the flywheel, or like a chunk of the aluminum transmission case? Either can be repaired, but having the case fixed will probably be more costly.
If it requires taking the transmission out to be fixed, you do not have to remove the engine.
Old Mar 25, 2007 | 07:01 AM
Default Re: 96 del sol clutch housing (91DA9)
It is a chunk of the transmission case. So replacing is probably a more costly solution than trying to repair? Do you know of a link that can show this step by step?
Old Mar 25, 2007 | 07:06 AM
91DA9's Avatar
No, I don't. You will want to use a good shop manual, or a Haynes. Do you have a picture of the damage?
If you have any racing shops around, they should be able to weld aluminum. The blocks on funny cars are so expensive they get reused even after it throws several rods.
Old Mar 25, 2007 | 10:12 AM
Bense's Avatar
d-series or b-series?
Old Mar 25, 2007 | 01:31 PM
Default Re: (Bense)
SORRY what is d or b-series?
Katarune
Aug 30, 2016 07:52 AM
H23_del_soul
Apr 12, 2010 08:33 AM
shady3260
Transmission & Drivetrain
Dec 19, 2009 10:27 PM
civictech22
Aug 17, 2004 03:49 PM
my2ndtool
May 24, 2002 10:35 AM
