2000 Em1 Vibration Under Acceleration (HELP)
Ok today i noticed when i start moving in first gear my car starts to vibrate really bad.but after that at higher speeds i dont feel it anymore. I have new tires and they were balance 1 month ago. Ive been search and other people said its most likely the axles (True?).. Also how do u check if the axle is bad. Signs?..any other posibilites of what it can be..
Modified by EM1OwnerSi at 6:44 PM 3/24/2007
If your axles are bad you would hear knocking noise when you're turning left or right.
- If it knocks when you turn left, left axle bad
- If it knocks when turning right, its your right axle
Besides the possibility that your bearings might be bad, it can be a few other things.
- maybe they didnt do a good job balancing your wheels
- something stuck on your tire
- ding on rim
- ball joint(s)
- tie rod(s)
- clutch might be wasted and misaligned (happened to me once)
I dont know if I covered everything but there's always room for
- ding on rim
- ball joint(s)
- tie rod(s)
97Alex
Aug 20, 2005 03:36 AM
xhatchracerx
Oct 23, 2003 01:05 PM
