Falken Azenis. what psi?
Old Mar 24, 2007 | 04:53 PM
EM1FORLIFE.'s Avatar
Default Falken Azenis. what psi?
i got falken azenis RT-615 205/50/15 last week and never asked the tire people what psi should i set it at. I checked today it was around 40-45psi, i think thats kinda high. So whats the correct psi? btw the wheels are stock 99-00 si wheels, if that matters at all. Should i put it at factory psi f/33 r/35 or keep it at 40ish? And i searched, not many threads came up, but the ones that did didn't have any info with 99-00 si wheels.
Thanks.
Old Mar 25, 2007 | 06:34 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Falken Azenis. what psi? (EM1FORLIFE.)
The pressure depends on the car, not on the wheels.
I advise starting off at the factory recommendation for your car - I suspect you got it backwards and it's 35 front and 33 rear, not vice versa (it's 35F/33R on my Integras, anyway). Pressures measured when cold (i.e. with the car at the outside temperature in which it will be driven, after sitting out of the sun for several hours). Try it with that. If you feel the need to adjust the pressures from there, for handling, ride comfort, tire wear, etc, you can do so in 2 psi increments. But that's usually the best place to start.
Old Mar 25, 2007 | 08:05 PM
supersteven's Avatar
I run 35 all around.
euclid
Mar 19, 2003 06:59 PM
Fuster_Cluck
Aug 20, 2002 03:25 PM
gblaue
Jul 25, 2002 03:27 PM
Neo
15
Apr 21, 2002 03:20 AM
Fooman
Jul 16, 2001 10:05 PM
