Quick, simple, vtec wiring question. Someone help please!
I recently picked up a crx si with a y8 head and z6 block. I'm running a z6 stock map on a chipped p28 and adjusted the timing with the dizzy so it's straight. Now for solving the other problem: vtec
All my previous hondas have had vtec pre-wired so I've never messed with it. What do I need to do to get vtec working on a p28? Right now, I have the vtec solenoid wired to a4 on the ecu. Do I need the vtec oil pressure switch wired up as well?
If so, someone please give me direction.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jorsher »</TD></TR><TR><TD CLASS="quote">I recently picked up a crx si with a y8 head and z6 block. I'm running a z6 stock map on a chipped p28 and adjusted the timing with the dizzy so it's straight. Now for solving the other problem: vtec
Thanks</TD></TR></TABLE>
Yes you do if you want Vtec to work
. Just look in a haynes manual ($15.00 at autozone) for 92-95 civic and it will show just what you need
accord2civic2prelude
Engine Management and Tuning
Mar 1, 2014 01:42 PM
mikej94civex
Dec 12, 2009 02:52 PM
user 98292739
13
Apr 26, 2005 04:16 PM
