Balance shaft Removal??????s
I wanted to know how hard is it to do this modification while the motor is still in the car? if its possible is there a DIY for this while the motor is still in the car?
complete removal like pull them out? I don't think you can do it while its in the car.
You can always just pull the belt and not run them. Thats simple to do.
I talked to reid at Kaizenspeed and he said removing the balance shafts while the motor is in the car has been done. When i removed mine it was out of the car and on an engine stand and it was still quite a bit of work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludestud11 »</TD></TR><TR><TD CLASS="quote">I talked to reid at Kaizenspeed and he said removing the balance shafts while the motor is in the car has been done. When i removed mine it was out of the car and on an engine stand and it was still quite a bit of work.</TD></TR></TABLE>
yeap it does take some work check this out http://www.kaizenspeed.com/news/article.src?ID=29
and drop rotating assembly weight. From what i have read, they are good for ~8whp. If you have the engine apart already, 125 shipped is pocket change to remove them.......might as well. Dunno if I would do it with the engine in the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">and drop rotating assembly weight. From what i have read, they are good for ~8whp. If you have the engine apart already, 125 shipped is pocket change to remove them.......might as well. Dunno if I would do it with the engine in the car.</TD></TR></TABLE>
Did you remove your Balance shafts???
