Cams
Old Mar 24, 2007 | 01:56 PM
jit01's Avatar
Default Cams
Hi I was wondering if I get gsr cams put in my b16a3 motor will it make a diff ? maybe pull harder when I am in vtec ? I won't need to get tuned right ?
Old Mar 24, 2007 | 10:34 PM
hondasarethebest's Avatar
Default Re: Cams (jit01)
Tuning is the best mod so if you can get it tuned you will feel a huge difference..
Old Mar 24, 2007 | 10:52 PM
jit01's Avatar
Default Re: Cams (hondasarethebest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondasarethebest &raquo;</TD></TR><TR><TD CLASS="quote">Tuning is the best mod so if you can get it tuned you will feel a huge difference.. </TD></TR></TABLE>
What would be better skunk 2 stage 1 cams or gsr cams ? I am not going turbo just want something that will give me a bit more hp and I am good. How much do gsr cams go for ? and do I have to get cam gears ? will that make much of a diff ?
ps: I will like to keep my idle the same and I will be getting street tuned with crome
Old Mar 25, 2007 | 08:42 AM
excivicboy96's Avatar
Get CTR Cams
Old Mar 25, 2007 | 09:10 AM
fmrprojects's Avatar
Default Re: Cams (excivicboy96)
with a b16 swap and just a cam swap to a gsr cams, you wont feel any difference. swap in a gsr block or ls block and mill the head a bit and you will notice the difernce
Old Mar 25, 2007 | 10:29 AM
del_slow420's Avatar
Default Re: Cams (fmrprojects)
just get either skunk stg 1's or itr/ctr because u dont need to upgrade the valvetrain and the cams are pretty close no u wont feel gsr cams even if u did put it on a dyno
jksmith
Nov 3, 2008 05:52 PM
sonny0330
Jul 18, 2007 01:24 PM
Sketch_hs
Aug 23, 2005 09:44 AM
esp4life
Mar 8, 2005 12:25 PM
metal-x
Oct 5, 2003 06:59 AM
