Switching to Synthetic
Old Mar 24, 2007 | 01:50 PM
zirac50's Avatar
Default Switching to Synthetic
If you have over 100k miles on prelude and switch to synthetic oil, does damage some seals and causes to oil leak? lot of myth i heard but still not sure. Got Idea?
Old Mar 24, 2007 | 10:03 PM
InvaderTrax's Avatar
100k might be safe
Old Mar 24, 2007 | 10:30 PM
my9thtry's Avatar
Default Re: (InvaderTrax)
i did the switch myself at 125k and had to take it out because of major leaks it caused. your best bet would be to use one of the blended oils IMHO
Old Mar 24, 2007 | 11:31 PM
ilovemydc5's Avatar
Default Re: (my9thtry)
Start with synthetic blend for like 4 oil changes then convert it to full synthetic, converted mine to full synthetic yesterday im using mobil 1 full synthetic with a k&n oil filter.
Old Mar 24, 2007 | 11:40 PM
HondaTheory's Avatar
Default Re: (96Accordh22)
I have been running Full Synthetic Mobil 1 since I got the car 2 years ago. 163,000 miles and no leaks.
Old Mar 24, 2007 | 11:44 PM
anhthanh's Avatar
yah i wanna know too i just bought my 2000 prelude it has 163 xxx kilometers it about just over 100k miles just did a oil change on it and wasn't sure didn't want to use teh cheap one so went pennzoil platinum full synthetic ..wasn't sure wat the last owner used... is that gonna casue me any problems ???
Old Mar 25, 2007 | 12:14 AM
mkazm83's Avatar
Default Re: (anhthanh)
Depends on the condition of your motor. Synthetic does not "Damage" any seals, it simply cleans the motor better than conventional oil. This means that some seals might be gunked up, and synthetic will clean them, this can lead to leaks. You should be OK.
Old Mar 30, 2007 | 04:33 AM
xtal's Avatar
Default Re: Switching to Synthetic (zirac50)
I switched at 100k to 0W30 synthetic in winter and 5W30 synthetic for the rest of the year.
No problems. I had a minor oil leak on my VTEC solenoid filter, but I'm guessing that had zero to do with the oil being used and a lot to do with how I drive the car.
If you've got oil leaks, here's an idea : fix them, and they'll go away!
Behan
Sep 9, 2003 05:10 AM
ation
Apr 24, 2003 06:01 PM
GQ 05YellowEVO8
May 24, 2002 06:25 PM
G2_Integ
Aug 11, 2001 09:13 AM
