CEL on, battery light dim
Old Mar 24, 2007 | 01:25 PM
dblock91's Avatar
Default CEL on, battery light dim
91 civic si, car has power loss and battery light is dim
help
Old Mar 24, 2007 | 02:38 PM
typeR#0427's Avatar
Default Re: CEL on, battery light dim (dblock91)
my 89 integra was doing that last week, i just cleaned the terminals, and charged up the battery.
its fine now, have you had the alternator checked?
Old Mar 24, 2007 | 02:49 PM
onesikdb8's Avatar
Default Re: CEL on, battery light dim (typeR#0427)
One of the most overlooked maintenance items besides flushing the brake system is cleaning the battery terminals. Clean them off, clean the battery connections. Start the car then disconnect the battery, if the car dies, you have a bad alternator.
Good luck.
Old Mar 25, 2007 | 01:23 PM
dblock91's Avatar
Default Re: CEL on, battery light dim (onesikdb8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dblock91 &raquo;</TD></TR><TR><TD CLASS="quote">91 civic si, car has power loss and battery light is dim
help</TD></TR></TABLE>
i should have been a little more specific with my description,
the throttle cable was real loose, so i tightened it up, and after that the battery light went away. but the cel is still on and i think its throwin code 0 ( one long steady flash) when you give the car full throttle it hesitates until a higher rpm, it doesnt sputter but it just falls on its face, could it be the tps?? or fast idle valve?
hope that description is a little better
Old Mar 25, 2007 | 08:39 PM
onesikdb8's Avatar
Code 0 is ECU....Replace with a known working ECU.....
Bad_dude
Jan 25, 2011 07:10 PM
goliyong
Honda Civic (2001 - 2005)
Jun 20, 2007 06:31 PM
Vtecme92
Oct 10, 2005 07:18 PM
jeffchaisi
Aug 19, 2005 08:31 PM
itr1235
Jun 4, 2003 07:26 PM
