B16a second gen in a 00 ek
Old Mar 24, 2007 | 11:28 AM
AllMotorDB2's Avatar
Default B16a second gen in a 00 ek
I want to take my obd1 B16 and put it in my 00 EK.What all will I need to make this work.
I already have a jumper harness obd2 alternator and distributor.Is there anything else I will need to make this swap happen without throwing any codes.
Will my obd1 injectors work, and will it be a problem having no knock sensor because I will be using a obd1 ecu.
Also this motor is coming out of My DA will I need to use diffrent mounts.
All input is welcome, and thanks in advance
Old Mar 24, 2007 | 11:34 AM
pdiggitydogg's Avatar
You will need to use obd2 injectors, if youre using your 00 harness -- or you will have to swap injector plugs to use the obd1's.
You will throw a code for knock sensor (you can mount one easily enough - drill and tap a hole)
You will need all the B sereis to EK mounts (all from 99-00 EM1):
Rear "L/T/7" bracket
Timing side block mount
Also a hydro tranny front lower mount from any 94+ b series
please search next time and for more information...
silverh23ek
Jan 11, 2006 10:26 AM
Ekay Jay
Dec 21, 2005 07:23 PM
s2000june
Dec 19, 2004 04:16 AM
boot machine 5000
Mar 16, 2002 08:09 AM
DR. ON POINT
Oct 29, 2001 06:05 AM
