electrical help!!!!!!
Old Mar 24, 2007 | 09:41 AM
creek accord's Avatar
Default electrical help!!!!!!
I have a 92 honda accord with h22a swap, I have power to my fuse box under hood but no power to the inside/ignition inside the car!!! what main harness give power to the in car fuse box/inside car????
checked fuses inside and out checked plugs.....over and over again....
Old Mar 25, 2007 | 04:19 PM
305-H22A's Avatar
have u check your fuses maybe one is blown,there is a solid yellow wire,and a solid white those are main power to the inside of the secondary fuse box the one inside the car.folllow the wire maybe u have a short somewhere in the system.
Old Mar 25, 2007 | 05:48 PM
arc_55's Avatar
you need to get a good wiring diagram and follow back to see how the ignition system is run. Check and corresponding fuses and check for power up until the ignition switch and even after to find your problem. However a good wiring diagram is what you should be looking for. Also some good tools would be a test light and a multimeter.
fatsalmon15
Audio / Security / Video
Apr 10, 2014 06:44 AM
94trouble
Sep 18, 2013 06:08 AM
ExVtec
Honda S2000
17
Mar 18, 2009 05:19 PM
94Gizzer
Mar 5, 2003 04:11 AM
importfan85
Dec 30, 2002 11:54 AM
