sohc injectors same as dohc injector s
Old Mar 24, 2007 | 08:09 AM
EK FLY's Avatar
Default sohc injectors same as dohc injector s
is it fine to run sohc injectors in a gsr motor , these are obd2 injectors is there any difference btween those injectors ?
Old Mar 24, 2007 | 08:13 AM
. a d a m's Avatar
Default Re: sohc injectors same as dohc injector s (super-hatch)
are we talking about stock injectors here or what?
Old Mar 24, 2007 | 09:07 AM
pdiggitydogg's Avatar
yes
b and d series injectors are all 240cc
Old Mar 24, 2007 | 09:31 AM
03akkord5spd's Avatar
Default Re: (pdiggitydogg)
d-series sohc vtec injectors are 240, non-vtec d-series injectors are 190 i believe....just to clear things up.
Old Mar 24, 2007 | 10:34 AM
EK FLY's Avatar
Default Re: (03akkord5spd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03akkord5spd &raquo;</TD></TR><TR><TD CLASS="quote">d-series sohc vtec injectors are 240, non-vtec d-series injectors are 190 i believe....just to clear things up.</TD></TR></TABLE>
woukd it hurt to use the sohc non vtec on a gsr ?
Old Mar 24, 2007 | 10:45 AM
ive never heard/seen that before
Old Mar 24, 2007 | 11:00 AM
Default Re: (super-hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super-hatch &raquo;</TD></TR><TR><TD CLASS="quote">woukd it hurt to use the sohc non vtec on a gsr ?</TD></TR></TABLE>
i would definatly think so. try going to a local junkyard to find some 240s...
Old Mar 24, 2007 | 03:00 PM
EK FLY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03akkord5spd &raquo;</TD></TR><TR><TD CLASS="quote">i would definatly think so. try going to a local junkyard to find some 240s...</TD></TR></TABLE>
ow well here is the thing
when I run my stock obd1 cx ecu the engine runs fine and when I put the obd1 p72 it runs like crap , backfiring , misfiring and all those thing
Old Mar 24, 2007 | 10:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super-hatch &raquo;</TD></TR><TR><TD CLASS="quote">ow well here is the thing
when I run my stock obd1 cx ecu the engine runs fine and when I put the obd1 p72 it runs like crap , backfiring , misfiring and all those thing </TD></TR></TABLE>
yea i'm sure it would run better cuz you have the cx ecu running cx injectors. the cx injectors will prolly work fine for daily driving but i def wouldn't be romping on it and taking it up to redline and crap with the cx gear
Old Mar 24, 2007 | 10:11 PM
92ehatch's Avatar
is this true? im using d series non vtec injectors on my z6 and it seems fine
Old Mar 25, 2007 | 12:53 PM
Default Re: (92ehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch &raquo;</TD></TR><TR><TD CLASS="quote">is this true? im using d series non vtec injectors on my z6 and it seems fine</TD></TR></TABLE>
non-vtec d-series are either 190 or 180, i've read it several times on d-series.org...
BoostedD15B7
Jul 15, 2002 03:38 AM
JDMvtecDRAGSTA
May 29, 2002 08:27 AM
lucas569
Apr 18, 2002 05:24 PM
