timing belt, how tight?
Old Mar 24, 2007 | 07:51 AM
bfeils's Avatar
Default timing belt, how tight?
I've been hearing a rattle in the timing belt side of my h22 lately so I popped the valve cover to check the timing belt and I can push it around on the pulleys with my finger no prob. Is this normal or is my tensioner gone? belt is in good shape car has 66,000 miles good compression. Recently uninstalled my supercharger.
Old Mar 24, 2007 | 08:25 AM
preylude's Avatar
Default Re: timing belt, how tight? (bfeils)
That is a loose belt. Check the tensioner. If I were you, I would replace the hydraulic tensioner with the mechanical one from an H23. It isn't very difficult and it is much more reliable.
Old Mar 24, 2007 | 10:20 AM
bfeils's Avatar
Default Re: timing belt, how tight? (preylude)
Yep, I removed the timing belt middle cover and ran the engine and watched the belt when I revved the engine. When it started making noise the belt was flappin all over the place. Oh well the other reasons for that noise could be alot worse.
WiedemannC
Dec 6, 2010 12:35 PM
airikkCRX
Apr 2, 2010 08:29 AM
SPIKE'S91CIVICSI
Mar 9, 2009 03:11 PM
Imprezn
May 6, 2003 01:36 PM
