Remedy for vtec leaky head gasket, anyone? (oil)
Old Mar 24, 2007 | 05:12 AM
JDMs1eeper's Avatar
Default Remedy for vtec leaky head gasket, anyone? (oil)
I've noticed on several DOHC B series Vtec setups that the front left corner is common to have a slow oil leak.
Has anyone noticed this?
Is this something that is an "install error" or is their a remedy to fix/prevent this leak?
Several motors I've owned have had this leak (LSvtec, CRVtec, B16 and GSR) along with several local engines in the area & @ the track. Seems like this is common but i know is fixable.
Does anyone have the Remedy or a Trick to prevent this?
(i'll post a picture of the area I'm referring to in a moment)
EDIT:
This is with a OEM Honda Head gasket by the way.
Modified by JDMs1eeper at 11:10 AM 3/24/2007
Old Mar 24, 2007 | 07:08 AM
JDMs1eeper's Avatar
Default Re: Remedy for vtec leaky head gasket, anyone? (JDMs1eeper)
Old Mar 24, 2007 | 05:49 PM
Cimburke23's Avatar
Old Mar 24, 2007 | 07:04 PM
Echo7847's Avatar
Default Re: Remedy for vtec leaky head gasket, anyone? (Cimburke23)
Mine doesnt leak
Could be do to warped head/block, improper install, vtec sol gasket, dizzy o-ring, cam plug...
Old Mar 24, 2007 | 08:10 PM
91DA9's Avatar
Default Re: Remedy for vtec leaky head gasket, anyone? (Echo7847)
I agree, I have seen many cars with this problem and Echo has a point that there are lots of parts around there that can slowly leak oil, which will collect on the headgasket because it sticks out.
It does seem like that side would be more prone to warpage, even with the transmission bracing it, they have to support a heavy flywheel/clutch assembly creating a lot of rotational inertia.
Old Mar 25, 2007 | 02:54 PM
EF8IGHT's Avatar
Default Re: Remedy for vtec leaky head gasket, anyone? (91DA9)
check your exhaust cam seal, that notoriously goes bad and leaks down to the hg.
Old Mar 26, 2007 | 07:16 AM
mmuller's Avatar
Mad Scientist
Default Re: Remedy for vtec leaky head gasket, anyone? (EF8IGHT)
so have you figured out its not your head gasket yet?
there is 2 oil pressure points on the head, 1 in the middle of the intake side and the other by cyl#4 on the intake side; 1 to feed the head and 1 to feed vtec.
the only oil gallery close to that side of the head its a drain, which has no pressure, alias if it was really leaking from there you would be spitting coolant also.
Old Mar 26, 2007 | 05:51 PM
JDMs1eeper's Avatar
Default Re: Remedy for vtec leaky head gasket, anyone? (mmuller)
I removed the allen head plug on the back of the head, cleaned & sealed it. 100 miles later... Dry
Thanks guys for the reply. I'll Post a pic this week of the plug for people to see who may come across this thread.
Old Jun 29, 2007 | 11:48 PM
Nisif's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMs1eeper &raquo;</TD></TR><TR><TD CLASS="quote">I removed the allen head plug on the back of the head, cleaned & sealed it. 100 miles later... Dry
Thanks guys for the reply. I'll Post a pic this week of the plug for people to see who may come across this thread. </TD></TR></TABLE>
What plug were you referring to? I've encountered the same problem, wondering if you ever had a chance to take pics.
Old Jun 30, 2007 | 06:13 AM
egsleepercivic's Avatar
a leaky dizzy o-ring, cam plug, or vtec solenoid will deposit oil on the part # of head gasket
gl
Old Jun 30, 2007 | 09:57 AM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote"> oil gallery</TD></TR></TABLE>
no you didn't!
Old Jun 30, 2007 | 10:08 AM
93widebodyeghatch's Avatar
mine started leaking recently but since im building the new motor i dont think im gonna worry about it hence the fact i removed vtec anywho
diegorra
Nov 30, 2011 10:57 PM
danielblushtein
Mar 11, 2009 03:34 AM
eg6madness
Oct 5, 2007 02:50 AM
JDMs1eeper
Mar 28, 2007 06:37 PM
