best ecu b16 n/a eg hatch?
I just bought a b16 eg for 4500. its got a p28 for a m/t ex right now. its redlining around 7500 so i dont believe its chipped. what is the best ecu for me to use. where do i get it from. whats the best place to get a ecu for my set up with out sending my own in. ive got i/e and im planning on i/h/e camshafts and gears for my final set up. no big plans for the car. also ive got the power steering taken out and the a/c out.
well if you are going that far into the car, keep the ecu and use crome or some sort of management that uses a socketed ecu. i have an 83mm gsr trying for 650+ and i am using a p28 with hondata. if you are really worried about it and dont want to run an ems, get a p30 thats the del sol vtec ecu. the p72 will work but will have that hiccup from the iab's not being there. if the engine is stock, the p30 will suit you. you can use a p28 on a dual cam you just need to set the rev limit accordingly.
HondaScene
15
Feb 9, 2012 11:50 AM
Jdm_Ego
12
Sep 27, 2010 03:42 AM
